08-23-2023, 09:49 AM | #1 |
292 rod bolts
Anyone have a set of 292 rod bolts they would sell
It is for a 1955 mercury with EBU rods I am located in sw pa . Thanks Ron Fox |
08-25-2023, 04:11 AM | #2 |
Re: 292 rod bolts
Maybe contact http://www.ford-y-block.com/ for a fresh set.
08-25-2023, 09:31 AM | #3 |
Re: 292 rod bolts
Got on his website and says arp rod bolts not available
.I would buy some good used ones if anyone has some for sale. |
08-26-2023, 06:35 PM | #4 |
Re: 292 rod bolts
Try Eggie Machine in Texas.
08-26-2023, 07:31 PM | #5 |
Re: 292 rod bolts
Ron, you don't want to use used rod bolts. When they are torqued, they stretch. One of the ways of checking that they've been properly torqued is by measuring them. Others might say to go ahead and use them, but are you willing to take the risk? I'm not.
08-26-2023, 10:37 PM | #6 |
Re: 292 rod bolts
08-26-2023, 11:22 PM | #7 |
Re: 292 rod bolts
Whether torque-to-yield or not, I still wouldn't use 68-year-old rod bolts. Before going that route, and risk spinning a bearing/throwing a rod, I would buy a new set of rods.
I think Ron has dealt with John Mummert (ford-y-block.com) and is probably aware that he does have H-beam rods that include new fasteners. They aren't cheap at about $500 for a set, but if built right, he should have considerably more invested in his engine than that. Sometimes you either pay now or pay later. Try contacting either Tim McMaster or Ted Eaton, either of whom might have a more affordable (and safer) solution than reusing old rod bolts. |
08-27-2023, 09:47 AM | #8 | |
Re: 292 rod bolts
You are correct in that using used rod bolts is like a crap-shoot (IMO).
- AT MY AGE, ONE APPRECIATES A STURDY HANDRAIL - |
08-27-2023, 11:08 AM | #9 |
Re: 292 rod bolts
I appreciate all the feedback. The only bolt manufacturer I have found is arp
. They call for a 6005 bolt that doesn't work for me. The threads on the new bolt are too short. Does anyone know of another bolt manufacturer? That's why I have been looking for used Tim McMaster has a set of used rods he would sell me. Might end up going that route. I assume a machine shop would have to change out the pistons? |
08-28-2023, 07:11 AM | #10 |
Re: 292 rod bolts
May seem like a simple question but Have you checked with local machine shops? Maybe one that’s been around awhile?
08-28-2023, 07:30 AM | #11 |
Re: 292 rod bolts
FORD CATALOGING calls for C1AE 6214-A - 3/8in - 24 X 2.10 which converts to 2 3/32in L (I believe).
ARP 154-6005 calls for their L as 2 7/32in (EBU) (again, I believe). If anything they are longer. Why not call ARP TECH and talk with them maybe? FORD also cataloged the same rod bolt for the early FE. *** EDIT - 1955-56 MERC CHASSIS CATALOG - JAN 1956 Original PN - EAA 6214-B - 3/8in - 24 - 2 1/16in L Last edited by KULTULZ; 08-30-2023 at 05:25 PM. |
08-28-2023, 10:29 PM | #12 |
Re: 292 rod bolts
may be dumb question but only bolts I know of in an engine that can be measured after being torqued are rod bolts. how do you measure for correct torque on all the bolts that the heads are the only thing visible?
08-28-2023, 11:47 PM | #13 |
Re: 292 rod bolts
More than you probably want to know about bolt torque/stretch/yield etc. More interesting reads on the site. It’s their web site, not an engineering manual, so judge accordingly
https://arp-bolts.com/p/technical.php |
08-29-2023, 06:12 AM | #14 |
Re: 292 rod bolts
How about something like a SCAT rod? Their entry level rods would be more that good for you. If they made them for a 292...
08-29-2023, 06:21 AM | #15 | |
Re: 292 rod bolts
Other bolts (cap screws) are torqued to value or torqued to yield however the fastener supplier describes or the engine builder recommends maybe in a HP application. EDIT - It is not mandatory a stretch gauge be used. Only for the particular. I wonder what TED EATON has to say about this?
- AT MY AGE, ONE APPRECIATES A STURDY HANDRAIL - Last edited by KULTULZ; 08-29-2023 at 06:31 AM. Reason: THE USUAL - CRS |
08-29-2023, 06:28 AM | #16 |
Re: 292 rod bolts
Here is one possibility. The PN I showed (C1AE - year 1961) is a later service replacement number. It may be the assembly rod bolt was longer.
The ARP bolts seem to be readily available. I wonder why John Mummert said they were not. Wish he had given an explanation. If the rod is resized and magnafluxed, I see no reason for aftermarket unless the engine is going to be a high revving. FORD did offer a steel crank and rods on MT. |
08-29-2023, 04:43 PM | #17 |
Re: 292 rod bolts
I wonder how many 292 equipped Fords with rebuilt motors using the same rod bolts, crank cap bolts, etc are parked at the Saturday car shows.
08-29-2023, 05:56 PM | #18 |
Re: 292 rod bolts
It could be that it's not a matter of ARP availability, but that they don't fit. For years, ARP put the retaining clip of the oil pump drive shaft on the wrong end.
08-30-2023, 06:17 PM | #19 |
Re: 292 rod bolts
https://egge.com/ Call them. And I mean pick up the telephone.
08-31-2023, 06:41 AM | #20 | |
Re: 292 rod bolts
Maybe someone can post this thread @ y-blocksforever.com and TED can catch it and answer. |
