08-17-2023, 09:54 PM | #1 |
Is crack in block visible to naked eye.
I removed the head on my 59 AB and discovered water in 7 & 8. This is either a gasket problem or a crack in the block. If I cannot see a crack in the block at the valves, with normal sight acuity, can I safely assume that this is a gasket problem?Photos are attached if that may help.
Your thoughts are appreciated. Phil Last edited by 47topless; 08-17-2023 at 10:01 PM. |
08-17-2023, 10:35 PM | #2 |
Re: Is crack in block visible to naked eye.
Photo of my block that has water entering into cylinders 7 and 8 - 47topless |
08-17-2023, 11:20 PM | #3 |
Cracks can be where they cannot be seen. That is why you do a pressure test.
08-18-2023, 06:39 AM | #4 |
Looks like fire ring leaks to me. Try new gaskets to find out. Smear them with plenty of wheel bearing grease.
08-18-2023, 07:14 AM | #5 |
If you want to inspect it more, buy a fine wire brush and some lacquer thinner or acetone and carefully clean the transfer areas between the valves and the bores. Then use a very bright light to inspect.
In many cases one can actually see a crack in this area. The only way to be sure is to take the engine apart, have it cleaned, magged and pressure tested. Lots of work (and some $$$) to find-out it may not be cracked. I'd try the new head-gasket approach first - just to see if that was the issue. I'd probably buy a set of Best Gaskets GraphTite head gaskets. |
08-18-2023, 07:15 AM | #6 |
I broke a damned valve stem, while removing the other head, so I'll need to fix that first. Thanks again, Phil |
08-18-2023, 07:17 AM | #7 |
mag or dye test to be sure but be warned the dye can be a bugger to clean off after the test
08-18-2023, 09:00 AM | #8 |
Try the Best brand gaskets as advised above, leave the wheel bearing grease for the wheel bearings. Retorque at least 3 times after heat cycling after initial start up. Have the heads checked for flatness or get them surfaced.
08-18-2023, 10:24 AM | #9 |
08-18-2023, 07:49 PM | #10 |
I'm on board with the "Big Deuce" - he has it right!
08-18-2023, 08:16 PM | #11 |
I ONLY use wheelbearing or chassis grease on gaskets.
08-19-2023, 02:57 PM | #12 |
08-19-2023, 04:18 PM | #13 |
08-19-2023, 07:40 PM | #14 |
08-19-2023, 10:01 PM | #15 |
