08-16-2023, 08:27 PM | #1 |
1951 temp gauge issue
1951 Ford Flathead
Temperature gauge before start up..............H (as it should) Gauge after start up........................................C (as it should) Gauge after warmed up engine.....................C+ plus a very little (malfunction) Shut engine off....turn on key......temp gauge now shows proper temp. Start engine again............................................. C+ plus a very little (malfunction) Changed both temp sending units with known good working ones....same result as above. Help!! Any ideas??? |
08-16-2023, 10:59 PM | #2 |
Re: 1951 temp gauge issue
Too much Teflon tape creates a grounding issue at the senders. Leave off the Teflon and use pipe thread dope instead.
Alan |
08-17-2023, 01:18 PM | #3 |
Can you by pass the ignition switch? If so, then start the car and see what happens.
Perhaps switch is faulty. |
08-17-2023, 03:24 PM | #4 |
