Old 08-13-2023, 12:32 PM   #1
flathead 53
Default 1967 fairlane,front end alignment specs
looking for front end alignment specs for A 1967 fairlane 500 with manual steering.
flathead 53 is offline   Reply With Quote
Old 08-13-2023, 03:14 PM   #2
cadillac512
cadillac512's Avatar
Default Re: 1967 fairlane,front end alignment specs
stock Ford Specs were:
0 +-1 Deg Caster (A couple degrees more is better if you can get it)
+ 1/4 +-3/4 Deg Camber
1/8" Toe-In
Maximum diff between wheels not to exceed 1/2 deg
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'30 Model A Speedster
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 08-13-2023, 03:48 PM   #3
55blacktie
Emphasis on "stock."
55blacktie is offline   Reply With Quote
Old 08-14-2023, 06:00 AM   #4
Ole Don
Ole Don's Avatar
If you can find a really good front end man, he will tell you the stock specs are only a suggestion.
Ole Don is offline   Reply With Quote
