08-09-2023, 07:31 AM | #1 |
Advance lack of response on RPM on a 31
What would cause a lack of rpm when the advance is advanced. The rpms do not increase as you would expect. The car actually runs worse with even 1/2 to 1" of advance.
I have tried a different dist body that has different body cutouts, different length of advance rods, checked the timing gear teeth, and turned the steering column with no changes. Compression 68 62 50 60 Pertronix electronic ignition. The car starts great, idles good and is timed perfectly. Last edited by old31; 08-09-2023 at 04:08 PM. |
08-09-2023, 07:46 AM | #2 |
Re: Advance lack of response on RPM on a 31
How long has this lack of response been going on?
08-09-2023, 08:32 AM | #3 |
Fault is in the electronic ignition. The Ignitor is not reading the advance of the distributor shaft.
Bob Bidonde Last edited by Bob Bidonde; 08-09-2023 at 08:38 AM. |
08-09-2023, 10:08 AM | #4 |
Try a distributor with an old set of points in it if you can, if it runs better or ok then that probably confirms what Bob said
08-09-2023, 10:19 AM | #5 |
Bob, other than installing points, do you know of any test that can be done on the Pertronix?
08-09-2023, 12:59 PM | #6 |
08-09-2023, 01:14 PM | #7 |
“When the advance is advanced” seems to indicate a manual advance ignition? Is this true?
08-09-2023, 02:35 PM | #8 |
Sounds like the initial timing is too far advanced to me. Then you manually advance it more and it is advanced too far and she's not liking it.
08-09-2023, 08:05 PM | #9 |
I have the Pertronix on the A and my other classic cars, never had a failure just set it and forget it. When I got the A a year ago the Pertronix was one of the first changes I made. Timing of the A seemed a hit-and-miss proposition to me. Using a test light or NuRex wrench got you in the ballpark I think, you more experienced guys may know better than I? I installed the timing scale that allowed me to use a timing light and set to an exact number whatever that may be. I believe the black Pertrinix module is just an on-and-off switch a dumb one at that. The red version is the smart one that will do more functions.
What is the perfect timing? I have come to believe that no two Model As are the same? |
08-09-2023, 11:13 PM | #10 |
As a newbie it seemed to me that the large range of manual advance/retard would make the initial timing less critical. You can home in on the optimal advance using the lever and feeling how the engine responds. Am I missing something? I’d love to understand my Model A better.
David in San Antonio 1930 ('31?) Deluxe "Wretched Roadster" Restored 1957 Alamo A’s Club |
08-09-2023, 11:48 PM | #11 |
David, you make a valid point but I think an accurate starting point is necessary. In my case, it may be more critical because I am using the NuRex spark advance unit. It is my belief that this unit does a better job of setting advance than I can manually even though it is not perfect. If my initial advance is not correct the NuRex will over or under advance. As it stands I find under full throttle I have to manually advance a couple of clicks more.
I have read that a high compression like mine at 100psi. requires less advance, My initial advance is set at 2 deg. ATDC and has worked well for me. |
08-10-2023, 12:03 AM | #12 | |
08-10-2023, 10:57 AM | #13 |
Well, I thought that Bob B was on to something in regards to Pertronix not seeing the advance, so I took my spare Pertronix and installed it. That did not make any difference with the advance and rpm.
I even took it for a ride with a loose steering column so that I could turn it and work the advance at the same time. That made no difference. I will install points and test it. I AM STUMMPED |
08-10-2023, 11:19 AM | #14 |
I set the timing using the Ford method; with the point gap set, spark lever all the way up, the timing pin in the dimple of the timing gear the points are set to just starting to open. Works every time. Was taught this back in the '50s. YMMV
If you don't hear a rumor by 10 AM, start one!. Got my education out behind the barn! Last edited by katy; 08-12-2023 at 11:50 AM. Reason: addition |
08-10-2023, 01:06 PM | #15 |
I have not had very good luck with electronic ignition. A lot of people swear by them but not me. I went back to the mechanical points and condensor. Although I do use V8 points and condensor.
08-10-2023, 01:18 PM | #16 |
NK, what are the differences with the v8 points vs the standard?
I am a huge proponent of electronic vs points. No condenser to go bad, nothing to adjust. Think about it, American auto makes have been using electronic since the 80's. When was the last time your new or antique car died due to the electronics. |
08-10-2023, 07:19 PM | #17 |
Last month. Not my car but my friend Ted. He was returning from a trip to Utah from California in his Model A when the electronic ignition module failed. He caries a spare distributor, with mechanical points, and put that in to continue home.
Several years ago I tried an electronic ignition module and the car developed a miss. I put the mechanical points back in and the miss went away. I followed the wiring instructions. My present Model A came with electronic distributor with automatic advance and I was not happy with its performance. I switched to a stock distributor and the performance was greatly improved. To be fair it was probably the advance curve that was wrong. Regarding V8 points. My stock Model A that I drove in high school had Ford factory ignition parts and i did not have to change the points or condensor for the decade and many miles I drove it. But another car I owned had after market points and condensor which had a very short life. The V8 parts, in my experience, are better quality than the repro points and condensors available today. That may not be the case with all repro parts available, just the ones that I bought. Like I said, many people are happy with electronic ignition systems. But I have not had very good luck with them.
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 08-10-2023 at 07:33 PM. |
08-11-2023, 08:09 AM | #18 |
Vacuum leak?
08-11-2023, 08:52 AM | #19 | |
08-11-2023, 05:18 PM | #20 |
I would install stock type points and condenser and test it.
Ruth "Sometimes you really DO need to read the whole thread" |
