#1 |
First time posting but been reading for a few years. I am having a machine shop build a 59ab for my 36 5window and got the call I needed 80 over cam bearings. I been searching for about three weeks and read all articles I could find and in one it listed NOS part numbers as 01A-6261-D and 01A-6262-D and I found these numbers for sale and I purchased. Now the boxes have D2 instead of D at the end of the part number. Does anyone know what the 2 stands for? Could it be a different ID?
#2 |
Super Moderator
The "2" indicates the part was sourced from a different supplier. It is interchangeable with the same basic number (D).
#3 |
Thanks
#4 |
I hope the machine shop is really trying to say you need .20 under bearings. If they ground that much off of the journals, I would be very concerned about the shop and you will need a new cam.
I've only seen .20 under bearings for sale. I've seen anything above that. |
#5 |
.20 inches is a lot of metal. Shouldn't it be .020?
#6 |
#7 |
Ford made and used cam bearings for most combinations of standard, oversize holes in the block as well as undersized journals on the cam. Make sure your bearings match the combination of specifications you need for your block and cam.
#8 |
If they're saying you need .080 oversize cam bearings, then they must be talking about the cam bearing bores in the block. Ford didn't like to scrap things, so I've heard they did over bore certain blocks for special oversize cam bearings (instead of throwing the block away). They obviously made oversize bearings for situations like this.
I've never had a block with oversize cam bearing bores . . . but the day is young! LOL If you cannot find the bearings, they may need to make them from aluminum bar stock. |
#9 |
I have these cam bearings for years and still do and sold many
#10 |
Fred to the rescue again!
#11 |
Fred, could you PM thanks, roncol1957
#12 |
"roncol" ...... Since you only have a total of 3 posts here on the F'Barn, you're not eligible (YET) to send or receive PMs. Ya need 10 posts to qualify for PM privileges. I have posted "barnfind08" (Fred Wilner's) contact info BELOW ..... you're going to have to contact him. Fred has nine buildings stocked with NOS old Ford parts, plus he is one of our own members here on the 'Barn. Fred is a GOOD guy!! Coop Fred Wilner - (barnfind08") SOUTHSIDE OBSOLETE 7136 200th St E. Faribault, MN 55021 (507) 332-6789 . |
#13 |
thanks, i will give Fred a call today
#14 |
Barnfind08-i am now in same place as this fellow was in 2023. I am in need of .080 over cam bearings for 59AB build. I finally ended up with good block after 3 unusable ones. Cylinder bores cleaned up at .040 over then the F1 durabond cam bearings too small. Any help is greatly appreciated.
Thanks Ron |
#15 |
Just pick up the phone and call him.
#16 |
I have them if Fred doesn’t.
#17 |
While I've never had a block with the cam bores like this, I'm sure the day will come . . . if I live long enough! I just picked up a pristine 'keystone' 41/42 Merc/WWII 239 block - STD bores, no apparent cracks (had been magged with new cam bearings installed), super clean decks, etc..
I will have the block cleaned again and magged, then I'll pressure test it. Hopefully all is well with it as these blocks are very hard to find. |
#18 |
Canada Ford was making WW2 Military engines '38 to '45, I have a '41 in my Canadian Merc. Factory relieved with a 3 3/16" bore. Newc
#19 |
Chrysler prod. was famous for odd bearings too. Also Fred is the man!
#20 |
So far after being involved in hundred's of flathead engine's I never came across any oversize cam bearing bores. Could it be possible during a short period of production the boring process for the cam bearing bores were machined incorrectly being to large a bore for the standard cam bearings. This would then be the reason for the needed oversize OD cam bearings. Makes one wonder why.
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587 |
