08-02-2023, 06:16 PM | #1 |
Early Model A Banjo?
Have two banjos, trying to decide on one for my car. Both are Model A.
I noticed on the one I planned to use there are no stiffening top or bottom rib which the other one does have. Is this less desirable/weaker? Is it an earlier banjo? There are also no numbers stamped on it indicating a gear ratio on the bottom.
waywardgarage.com |
08-02-2023, 06:58 PM | #2 |
Re: Early Model A Banjo?
The early banjos are prone to crack. My advice is to use one with the support gussets.
https://www.santaanitaas.org/wp-cont...jo-Cracked.pdf Tom Endy |
08-02-2023, 07:18 PM | #3 |
There won't be any numbers stamped on Model A banjos showing axle ratios. That was started later on the Flathead V8 cars.
08-03-2023, 11:28 AM | #4 |
Thank you guys!! That is just the information I needed and I'm very glad I asked!!
waywardgarage.com |
08-05-2023, 06:48 PM | #5 |
the early rear end has the pinion on the drive shaft and the later has the pinion on a separate carrier and is easier to change and set up.
old ugly my old father-in-law told me. "listen close when people tell you how to do stuff they may know something. then do it the way you want." |
