Old 07-30-2023, 07:17 AM   #1
Ed in Maine
Default 31 Rear Axle Rebuild
I am continuing my rear axle project and now have most parts disassembled. The pinion gear was removed from the drive shaft and the axle housings are off. Today I will take apart the with the carrier assembly and inspect the spider gears. My question is "are there any adjustments that need to be made when re-assembling the carrier." I am using Tom Endy's 2014 paper and will go thru the pre-load process without the axle shafts and spider gears first with no paper gaskets checking for ring gear lockup. However, upon re-assembling the carrier I want to be sure that there is nothing to be adjusted or shimmed.
Thanks for your help, Ed
Ed in Maine is offline   Reply With Quote
Old 07-30-2023, 08:48 AM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: 31 Rear Axle Rebuild
Ed, if you are 'shimming' anything, then something is outside of original specifications. There were some Differential Bearing Races at one time that a few vendors were carrying that were not made to original specs, so someone offered shims to place behind those to space them out. If the Differential gears are worn, then there will be excessive backlash between the axle gears, but shimming behind the gears is not the proper method for compensation IMO.
One of the things I find wrong with many axle housings is they are bent, -especially on the flange to Differential Housing areas. They really need to be heat straightened and then the flanges trued in a lathe if you are doing a proper restoration.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 07-31-2023, 03:34 AM   #3
john charlton
john charlton's Avatar
Keep all 3 spider gears as a set so driving load is evenly shared . If you replace one gear with a less worn one it will take ALL the driving load . I keep the spider gears on the spider where they have been so no new wear pattern also where and which way up the spider was in the carrier . I mark the carrier and spider so everything goes back as it comes out .
John in rain on the way again Suffolk County England .
john charlton is offline   Reply With Quote
