07-21-2023, 01:01 PM | #1 |
Evans heads
Does anybody know anything about Evans heads ???
History; pros; cons; ??? Found a pair; probably have them checked for cracks before I make the trade the guy wants to do. |
07-21-2023, 01:17 PM | #2 |
Re: Evans heads
There was great story on Evans in the Rodders Journal a few yrs back.
Here on EBAY: https://www.ebay.com/itm/17545497216...Bk9SR6bJ3ZqvYg |
07-21-2023, 04:29 PM | #3 |
Re: Evans heads
I believe both 60 and big V8 Smith and Jones heads are also Evans heads
07-21-2023, 04:52 PM | #4 |
Re: Evans heads
Back in the day most guys ran plain water so aluminum heads corroded around the water passage openings and head bolt holes. Heads were then milled to clean up the corrosion, resulting in too much metal being removed.
07-21-2023, 05:00 PM | #5 |
Re: Evans heads
07-22-2023, 02:34 AM | #6 |
Re: Evans heads
Evans employee parking lot in Whittier. Johnny Ryans' purple '32 Roadster with the white top in front of the Evans Foundry and Nellie Taylors blue '32 roadster, all ran Evans speed equipment. Those guys were so nice to me it made me a fan of the Evans equipment. I borrowed hundreds of photos and copied them. Earl Evans, Dan O'Regan and Nellie Taylor showing off the Evans equipment. August 31, 1947, SCTA Program. The fastest fifteen Class "C" roadsters. Fastest was Randy Shinn with a "T" body. Jack Calori, also my good friend had a '29 body on a '32 frame. Not sure of Warnock. I'm, pretty sure Jack Mickelson was the fastest '32 Roadster, followed by Nelson Taylor. Soon after this, Ed Stewart put a little nitro in his tank, and he became the fastest '32 roadster. He ran Evans heads and an intake too. The '32 roadsters could not compete with the "T" and "A" bodies running in the same Class, so there was always a separate rivalry going on for fastest '32 roadster bragging rights, but they did not set any actual records in 1947. If you look at the Gophers entries, you will see a lot of Evans equipment. They were a Whitter Club and Evans was in Whittier. Half the club worked there. A lot of the clubs were loyal to the equipment produced locally. Last edited by Flathead Fever; 07-22-2023 at 04:21 AM. |
07-22-2023, 05:03 AM | #7 |
Re: Evans heads
Thanks for your post FF.!!!
07-22-2023, 11:31 AM | #8 |
Re: Evans heads
If the heads are in great shape and have not been over-milled, I'd pick them up.
The chambers on the Evans heads were not much different than what everybody else was making -- Edelbrock, Offy, Navarro, Sharp, Edmunds, etc.. And all of them were basically what you'd get if you took a set of 59X heads and "filled/welded" up the transfer area to increase compression. Some guys tightened up the transfer area widths (like early Eddie Meyer), but in the end, they were all quite similar (other than chamber sizes and final compression ratios). Unless one was doing a lot of other experimentation and hand modifications (pop-ups, flat-tops, etc) - my bet is that none of them were really much better than the others. I say, run what makes yah happy! |
07-22-2023, 11:34 AM | #9 | |
Re: Evans heads
07-23-2023, 02:35 PM | #10 |
Re: Evans heads
Is there a specific reason why flathead spark plugs are NOT positioned above the pistons?
07-23-2023, 03:11 PM | #11 | |
Re: Evans heads
Yes. The combustion chamber is actually over the valves and transfer area. Getting the area over the piston as tight as reasonably practical is one of the tricks for a better running flathead. |
07-24-2023, 10:23 PM | #12 |
Re: Evans heads
I always savor the moments whan I meet and shake hands with well known or famous people and I have met quite a few, including Earl Evans and Babe Ruth.
07-24-2023, 10:28 PM | #13 |
Re: Evans heads
07-24-2023, 10:34 PM | #14 |
Re: Evans heads
07-26-2023, 06:11 AM | #15 |
Re: Evans heads
Thanks 38. JPL
