Old 07-20-2023, 07:48 AM   #1
54FordYBlockGuy
Default Adjusting Brakes on a 54
OK, got the 12-volt conversion problem somewhat solved; now going to attempt to adjust, and bleed the brakes on this 54 Customline. No power brakes, manual. The pedal is as hard as a rock, with very little movement, but she stops.
Q. What type of fluid to you suggest
Q. Is the bleeding done similar to a Power Brake Bleed, pump, crack the bleeder, and repeat until no air, nice flow.
Q. Any other adjustments required?
Appreciate the replies.
JPL/OH
54FordYBlockGuy is offline   Reply With Quote
Old 07-20-2023, 08:56 AM   #2
GLAmes
GLAmes's Avatar
Default Re: Adjusting Brakes on a 54
This has a lot of info not related to our fords, but plenty of information on brakes that is applicable. Brake fluid is on page 100.
https://s3.amazonaws.com/cdn.genosga...ection2021.pdf
'54 Skyliner. As close to original as I could restore it to.
GLAmes is offline   Reply With Quote
Old 07-20-2023, 09:51 PM   #3
Daves55Sedan
Daves55Sedan's Avatar
Assuming a previous owner did not convert your brake system to silicone fluid, you should use the OEM DOT3 hydraulic fluid.
But I'd find out for sure if I were you, because you cannot mix silicone (DOT 5) fluid with DOT 3 fluid.
Personally, I don't trust the one-man-pump and bleed procedure. There's enough time for air to rise in the system between the time you pump the pedal and get back down to open the bleeder screw. Use two guys (one at the pedal and another under the car).
Daves55Sedan is offline   Reply With Quote
Old 07-23-2023, 05:54 AM   #4
mercman from oz
mercman from oz's Avatar
54FordYBlockGuy's 1954 Ford Customline Fordor Sedan
mercman from oz is online now   Reply With Quote
Old 07-24-2023, 07:29 AM   #5
54FordYBlockGuy
Thanks for the information, and tips. I'll be putting all the wheels next week or so when I get back from Florida, and checking out the brakes. Possibly changing pads and turning drums; let's hope that's the extent of my brake repair. As for bleeding and not mixing two fluids; I'll be using the "two-man" approach, which always worked better for me; and possibly draining whatever fluid is in there now and putting in new, just so any mixing doesn't occur. Again thanks and I'll keep the group posted on the 54.
And thanks for inserting the Large Pic of the 54; as I noted before; past restoration, been sitting for some time, has a passenger "Black Eye", but GOOD BONES, should be a great 54 to cruise in.
Old 08-02-2023, 04:27 PM   #6
JeffB2
JeffB2's Avatar
JPL/OH
1952-54 Ford cars use the same brake shoes as 1967-71 Mustang V8 cars for about $60 you can convert your '54 to self adjusting brakes. POL also has shoes that are ceramic Kevlar that will reduce brake fade by about 25%. You can also upgrade to a dual master cylinder using the 1967-74 Mustang master cylinder for manual brakes for under $90
JeffB2 is offline   Reply With Quote
Old 08-02-2023, 05:49 PM   #7
Bob from Northport
Bob from Northport's Avatar
Who or what is the POL referred to above posting??
Bob from Northport
Northport, Michigan
Bob from Northport is offline   Reply With Quote
Old 08-02-2023, 08:08 PM   #8
JeffB2
JeffB2's Avatar
https://www.performanceonline.com/br...-ford-mustang/ And https://www.performanceonline.com/br...-ford-mustang/
Old 08-02-2023, 10:25 PM   #9
Bob from Northport
JeffB2- Do you know if those shoes you recommend will work/apply to a 54 mercury Monterey??? How about the spring kits???
Bob from Northport
Northport, Michigan
Old 08-05-2023, 03:59 AM   #10
JeffB2
JeffB2's Avatar
These would be the rears https://www.performanceonline.com/br...66-ford-f-100/ These are the fronts https://www.performanceonline.com/br...-malibu-ss396/ Funny your Mercury uses Chevy part numbers.
