Old 07-16-2023, 03:36 PM   #1
KenBolton
Default Starter Switch Non-Contact
Has happened several times with two different repo switches. Won’t make contact to turn the starter, then will several times then won’t. I’ve cleaned, greased with dielectric and replaced and it still happens. How could align the contacts for more surface area?
KenBolton is offline   Reply With Quote
Old 07-16-2023, 03:58 PM   #2
Bob Bidonde
Bob Bidonde's Avatar
Default Re: Starter Switch Non-Contact
This may help you:
Bob Bidonde
Old 07-16-2023, 04:51 PM   #3
Keith True
Keith True's Avatar
I haven't really had any trouble with the repro switches in the last 10 years or so.Couple of things that I have found out though.If you use a firewall insulator your shoe might bottom out before it makes good contact.I stretched out my starter rod,made a world of difference.The biggest thing I found was soft shoes can be a problem.That little pad pushes right up into soft shoe soles.The shoes made for people with foot problems,and issued by the VA are the worst.I have a pair of walking shoes that I have to work hard to push the starter button.Hard soled shoes just need a light push to do the job.
Keith True is offline   Reply With Quote
Old 07-16-2023, 07:35 PM   #4
Dave in Petaluma
Dave in Petaluma's Avatar
Keith, the same is true for aftermarket throttle return springs and soft-soled shoes. After a couple hundred miles, the throttle feels like it's coming through your shoe!
Dave in Petaluma is offline   Reply With Quote
Old 07-17-2023, 08:38 AM   #5
KenBolton
I appreciate the feedback!
Old 07-18-2023, 02:57 PM   #6
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
The angle of the hole for the push rod has been wrong. I put a large (12”) punch in and change the angle to match the original. That helps push the copper strip at the correct angle.
Old 07-18-2023, 06:30 PM   #7
Marshall V. Daut
Keith -
Have you considered installing an "Upstart" (or similar name) pull rod system? You by-pass pushing the starter rod with your shoe and simply pull up on the knob connected to the Upstart design. That depresses the starter switch and the starter turns over. The rod runs up next to the steering column on the right side. It's not all that noticeable and is easily removed for originality's sake. 'Might just make life easier for you in your Model A!
Marshall
