Old 07-15-2023, 10:43 AM   #1
Admiral
Admiral's Avatar
Default Oil Drain Plug Gasket
It's time to change the seal that goes on my car's oil drain plug. A small amount of oil is weeping out. It looks like I can get a copper gasket like the car has now or a fiber gasket. Is one better than that other? Any preference?
Copper
https://thirdgenauto.com/product/193...et-38-40-60hp/
Fiber
Admiral is offline   Reply With Quote
Old 07-15-2023, 11:23 AM   #2
cadillac512
cadillac512's Avatar
Default Re: Oil Drain Plug Gasket
Personally I like a high quality fiber gasket. Copper is good, but work hardens when tightened and doesn't conform to irregularities next time unless you anneal it. Buy a handful of good fibers to have on hand, check and snug it up after a few days and it's good.
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'30 Model A Speedster
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 07-15-2023, 11:32 AM   #3
petehoovie
petehoovie's Avatar
Copper
Fiber
Old 07-15-2023, 12:40 PM   #4
Kube
Super Moderator
Kube's Avatar
I believe the fiber type seals better.
Old 07-15-2023, 12:52 PM   #5
35fordtn
35fordtn's Avatar
Fiber is what I prefer. Some prefer copper... If you use copper it will work well but you need to be sure both mating surfaces have no burs.
On a side note I see your car is a 36 Does it have a later oil pan with the large plug? If not both of the gaskets you shared would be too large if it's a original 36 pan
35fordtn is offline   Reply With Quote
Old 07-16-2023, 12:13 PM   #6
Admiral
Admiral's Avatar
Thanks, guys. I was leaning toward fiber as well. Seems like it will conform better to a somewhat irregular surface should the pan or plug be less than perfect. For less than $2 I'll get a stack of them.
Thanks for the heads up. I'm running a 59L block, so yes, my car should have the large drain plug. The threaded portion is gigantic, around 2 inches in diameter.
Old 07-16-2023, 12:38 PM   #7
Krylon32
I prefer fiber. I always thought the copper gaskets needed to be replaced after each use as they take a shape and won't re-conform on the second use?
Krylon32 is offline   Reply With Quote
Old 07-17-2023, 10:53 AM   #8
oldford2
oldford2's Avatar
I used a rubber o'ring from the hardware store. No problem over many years.
John
oldford2 is offline   Reply With Quote
Old 07-17-2023, 12:52 PM   #9
Zeke3
Zeke3's Avatar
John
I do not recommend using a rubber o-ring for an oil drain gasket unless either the oil pan or the drain plug are machined with a counterbore to retain the o-ring.
Zeke3 is offline   Reply With Quote
Old 07-17-2023, 05:13 PM   #10
oldford2
oldford2's Avatar
Think about it
Old 07-18-2023, 12:51 PM   #11
Zeke3
Zeke3's Avatar
Thought about it and I still do not recommend using a rubber o-ring to seal a joint that is not designed for it. Rubber is an elastomer and will not resist the force of tightening the plug. It may squeeze out on one side or tear as the plug is being tightened. I am glad it has worked for you, but I won’t be using one on my car.
Old 07-18-2023, 01:27 PM   #12
hotcoupe
hotcoupe's Avatar
I have used copper and fiber, but my drain plug gasket of choice is leather. These are machine cut, and fit snug in the recess of the drain plug. No leaks.
Tom
hotcoupe is offline   Reply With Quote
Old 07-18-2023, 02:08 PM   #13
petehoovie
petehoovie's Avatar
Tom
Old 07-18-2023, 05:15 PM   #14
cadillac512
Tom
Great and elegant solution, Tom. Well done! I'm going to do the same next oil change...thank you!
Terry
