07-14-2023, 10:38 AM | #1 |
Push button starter
I am adding a push button solenoid for the starter. One thing I have not seen in the forum, is where people mount the push button. I would like to mount it up under the dash panel somehow. But, I would like to see what others have done first.
07-14-2023, 10:49 AM | #2 |
Re: Push button starter
I suspended a small panel from the left side of the dash rail and mounted 3 switches in it. One bolt and an angle bracket is all that was needed, a hand built angle bracket about 3/4" wide and bent 90*. The panel was formed from a scrap of aluminum. Sorry, no pics.
07-14-2023, 10:49 AM | #3 |
Hi IZZe I would suggest getting 2or 3inch momentary contact button on thfloor between the break and cluch pedal. for what's it's worth (free)
AL You can find one on line |
07-14-2023, 10:56 AM | #4 | |
X2 IMHO is preferable to have the push button on the floor. Leaves the hands free to operate the controls. |
07-14-2023, 11:19 AM | #5 |
Leonard Nettles is doing a run of starter buttons designed to be mounted where the original starter rod came through the floorboards. They should be shipping soon.
https://www.facebook.com/groups/1123...0063153779431/ (Sorry for those without Facebook, this is the only link I have.) |
07-14-2023, 12:36 PM | #6 |
07-14-2023, 12:39 PM | #7 |
I went one further, mine is a Key Start.
07-14-2023, 03:09 PM | #8 | |
07-14-2023, 03:28 PM | #9 | |
07-14-2023, 06:29 PM | #10 |
07-14-2023, 11:00 PM | #11 |
All right fellas. I hooked up the 6v solenoid. When I activate the solenoid, it just buzzes. But, there is button on the bottom of the solenoid that turns the engine over just fine when pressed. What did I do wrong?
07-14-2023, 11:18 PM | #12 | |
I have a 6 volt solenoid in my stash that the small terminal has to be routed to ground (thru the button) to activate the solenoid. |
07-15-2023, 12:41 AM | #13 |
I wired the negative battery terminal to the solenoid. Solenoid to the starter. Push Button is wired to the battery terminal on the solenoid, and to the S terminal on the solenoid.
I was testing the button without it being mounted to the car. Per your reply, I should mount the button so it is grounded? I can test that tomorrow. If I don't decide to start converting it to 12v. Damn thing barely turns over with 6v. |
07-15-2023, 04:37 AM | #14 |
Check your ground connections and cable sizes. My starter feed cable turned out to be smaller diameter than #4 cable!
07-15-2023, 09:08 AM | #15 | |
Here is a 6 volt solenoid that mounts on the Model A Starter Last edited by Y-Blockhead; 07-15-2023 at 09:14 AM. |
07-15-2023, 10:18 AM | #16 |
Just my 2 cents- you replaced a simple and reliable, foolproof starter switch with a complicated jiggered up system that you can't get to work. Unless you're missing your right foot or something like that, why?
07-15-2023, 10:25 AM | #17 |
This is the solenoid. It has three terminals. And has 6v stamped on the back.
Duralast Solenoid Switch F1490 I see that I do have a 2 gauge battery cable. I'll try swapping that out with 4 gauge. |
07-15-2023, 10:45 AM | #18 |
That solenoid fits early Fords so the small terminal need to go to ground.
07-15-2023, 10:45 AM | #19 |
Proper restoration eliminates the need for most modifications.
#2 gauge should be heavier wire than #4, why replace it unless it has internal problems Do a proper voltage drop test and find the real problem, 6 volts is not the problem |
07-15-2023, 10:50 AM | #20 | ||
Excellent question! Last edited by Y-Blockhead; 07-15-2023 at 10:59 AM. |
