Old 07-02-2023, 07:10 PM   #1
hb32
hb32's Avatar
Default KR Wilson distributor fixture V-126
Scored one this morning and my wallet never left my pocket
Long story short, filling up the 32 pickup and got talking to a gentleman who was knowledgeable on flatheads. Told me he had a fixture for setting the distributor dwell and asked if I wanted it. Cleaned it up and will put it to work shortly.
hb32 is offline   Reply With Quote
Old 07-02-2023, 07:20 PM   #2
petehoovie
petehoovie's Avatar
Default Re: KR Wilson distributor fixture V-126
Old 07-02-2023, 07:53 PM   #3
SoCalCoupe
SoCalCoupe's Avatar
Lucky duck! Been searching for one of those for quite a while.
SoCalCoupe is offline   Reply With Quote
Old 07-02-2023, 07:56 PM   #4
hb32
hb32's Avatar
Proverbial “ right place at the right time “
Old 07-03-2023, 07:52 AM   #5
Terry,OH
Terry,OH's Avatar
Appears it has the adapter on top for the later distributor also.
Old 07-03-2023, 09:19 AM   #6
Don
Don's Avatar
I have one just like it with the adapter,nice tool to go along with sun machine…
DON P
Don is offline   Reply With Quote
Old 07-03-2023, 09:36 AM   #7
mcgarrett
I was fortunate to find one too, with instruction sheet. I enjoy setting up my distributors knowing that they are properly adjusted with this tool. Love it!
mcgarrett is offline   Reply With Quote
Old 07-05-2023, 06:06 PM   #8
hb32
hb32's Avatar
So I must be missing something. I put a crab style distributor in it but it doesn’t seem to go down far enough to meet the, for lack of a better description, the wheel that turns on the fixture.
Old 07-05-2023, 07:09 PM   #9
SoCalCoupe
SoCalCoupe's Avatar
The 2-hole ring on top is an adapter to the 3-hole timing tool. It requires another adapter to extend the 2-hole shaft to the bottom of the tool. It looks like this. You can go to a similar fixture for sale last year on H.A.M.B. and see the adapter in the kit. The picture is from Speedway motors catalog. I don't know if would work on the KR Wilson tool or not.
Old 07-05-2023, 10:08 PM   #10
Karl
Karl's Avatar
I have one but never use it - I have a 'Bear" Gauge which is easier to use and allows you to set up both the left and right points with much more accuracy than the KRW unit
Such a fine sight to see-Its a Girl, My Lord, in a Flatbed Ford slowin' down to take a look at me.
Karl is offline   Reply With Quote
Old 07-05-2023, 10:40 PM   #11
petehoovie
petehoovie's Avatar
Picture, please...
Old 07-06-2023, 04:13 PM   #12
FlatheadTed
FlatheadTed's Avatar
Looking at that KR fixture someone has added two spacer plates ,that should take the crab then you remove them to do the Diver unit ,
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 07-09-2023, 01:15 AM   #13
hb32
hb32's Avatar
That looks like what I am missing
Old 07-09-2023, 02:02 PM   #14
hb32
hb32's Avatar
There is only one plate which is the adapter for the crab. Problem is, the crab doesn’t sit low enough to engage the degree wheel. As someone else mentioned, I am missing a piece to make up the difference
Old 07-09-2023, 02:03 PM   #15
hb32
hb32's Avatar
Thanks
