06-27-2023, 03:19 PM | #1 |
Aftermarket 2 blade aluminum fan
I just helped a fellow model a buddy get his 1931 model a coupe running. I noticed his original steel two bladed fan is cracked. I recommended he replace it with the aluminum one ASAP. It looks like everybody is out of stock on the aluminum one. Is there anybody that might have an extra one that they would sell or does anybody know anybody that has one in stock? We’ve checked all the usual vendors so far with no luck, he just got his model a running and now he can’t even enjoy it because for fear of that fan breaking and destroying the radiator and or hood.
Thanks.
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
06-27-2023, 04:29 PM | #2 |
Re: Aftermarket 2 blade aluminum fan
You can also use the 4 blade fan with great results. Check ebay...
06-27-2023, 04:32 PM | #3 |
Snyder's has a plastic fan. Doesn't look stock but at least he could drive his Model A
https://www.snydersantiqueauto.com/p...9280&cat=41698 Or Bratton's has a four blade metal fan. https://www.brattons.com/FOUR-BLADE-...uctinfo/12770/. |
06-27-2023, 07:07 PM | #4 |
Tried to find the aluminum fan also with no luck. I will probably buy the four blade fan.
Mike, how was the trip? I am going to install the pan tomorrow after I get back from the VA Dr. appointment. Still not sure about the 4th parade. |
06-27-2023, 08:02 PM | #5 |
06-27-2023, 08:18 PM | #6 |
sent you a PM... |
06-27-2023, 08:37 PM | #7 |
Steve Becker at Bert's told me a couple of weeks ago that he was expecting a large order of the aluminum 2-blade fans by the end of this month.
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan |
06-28-2023, 08:56 AM | #8 |
Try AZ Model A's. Sammy way have one.
06-28-2023, 11:01 AM | #9 |
He could try running w/out a fan, the Model Ts ran w/out them.
Anyone tried welding up a cracked steel fan blade? Just thinking about what maybe could be done in a pinch.
If you don't hear a rumor by 10 AM, start one!. Got my education out behind the barn! Last edited by katy; 06-28-2023 at 11:01 AM. Reason: addition |
06-28-2023, 11:34 AM | #10 | |
If you have seen the damage a steel fan blade makes/could make when it lets go. You would not drive the car or try to fix it. Should be replaced, Enjoy. |
06-28-2023, 11:50 AM | #11 |
If you buy used remember a lot of the early ones had quality problems.
Charlie Stephens |
06-28-2023, 12:43 PM | #12 | |
Hopefully, your favorite supplier has them back in stock soon |
06-28-2023, 06:14 PM | #13 |
I've welded the cracks & had long good luck with them. The rust bulges at the ends of the blade are another source of trouble.
06-30-2023, 03:39 AM | #14 |
Slightly OT: As a kid I remember loosing a fanblade on the A doing about 80 km/h on the highway. There was a loud bang, the blade went straight through the side causing a 3-4 cm long exit wound. It was very clean and neat and easy to fix.
Guess we were lucky Last edited by DkFordor; 06-30-2023 at 04:10 AM. |
06-30-2023, 06:42 AM | #15 |
I had my original fan go through my original radiator. It cost to have the car transported 100 miles, plus a reproduction radiator, new aluminum fan, shipping and the work to change it all. I now don't have an original radiator or fan.
Putting a reproduction fan on to begin with would have saved time, money and I would still have my original radiator. There are drawings and instructions for repairing an original fan by adding a doubler especially designed for that purpose. Maybe someone can remember where that was published. It looked almost correct when finished but did require some skill to achieve. Does anyone know how successful this was? |
06-30-2023, 06:58 AM | #16 |
The A-8600-A fans are finally due to arrive mid July. Our tooling was worn out and we had to re-tool the project and it took a lot longer than anticipated.
06-30-2023, 07:31 AM | #17 |
Welding a crack in the fan just delays the catastrophe! The fan suffers from fatigue, and welding / brazing hurts rather than helps. Welding a cracked fan is bad advice.
Bob Bidonde |
06-30-2023, 09:09 AM | #18 |
07-01-2023, 06:45 AM | #19 |
Thanks for all the suggestions guys I was able to find a new 1 for my friend
07-01-2023, 09:19 AM | #20 | ||
The fan was originally made from two raw stampings overlapped leaving the centre section with sharp edged stress risers and no solid connection between the two mating parts. Obviously Ford saw a flaw and made a change in 1931 which subsequently suffered the same fate! I'll elaborate on my question in the quote above in reference to the repair using the doubler. Was the idea to bridge the area assuming the the metal was only fatigued in the center and was okay otherwise? Has anyone seen this repair and are there samples of this method still surviving with or without being damaged? I'm just curious and not recommending anything. Any feedback, photographs? Thank you. Bob |
