Old 06-19-2023, 08:16 PM   #1
cvicky
cvicky's Avatar
Default y block ticking
272 started making what i thought was a manifold leek, so i poured tranny oil down the carb and the smoke exposed the leek at exhaust manifold wich is now fixed .
noise still there
i can rev engine 3500 rpm in neutral , NO NOISE then soon as i let clutch out and put motor under load noise appears and is obvious when acccellerating
cvicky is offline   Reply With Quote
