Old 06-13-2023, 02:33 PM   #1
mhsprecher
mhsprecher's Avatar
Default Woven vs molded linings for cast iron drums
There have been discussions on this topic earlier, but they are a bit dated. The consensus was that molded linings were better for cast iron drums than the woven linings. Of the major parts vendors, only one appears to carry molded linings, so it had me wondering what the current thinking on this topic is?
Fwiw, I am putting cast iron drums on the roadster in my avatar. The TS in the back already has them.
1910 Model T Touring
1924 Model T Coupe
1928 Model A Roadster
1930 Model A Town Sedan
1939 Deluxe Fordor
1945 pickup
1951 Custom convertible
mhsprecher is offline   Reply With Quote
Old 06-13-2023, 03:05 PM   #2
arnhemmer
Default Re: Woven vs molded linings for cast iron drums
I'm using the molded linings with the cast iron drums. Before they went to disc brakes all modern cars had molded linings with their cast iron drums.
arnhemmer is offline   Reply With Quote
Old 06-13-2023, 03:40 PM   #3
Marshall V. Daut
Order the brake shoes with molded linings arched to match new cast iron drums from Randy Gross in California. These linings give a firm pedal feel, while woven linings result in a softer, mushier pedal. I have both and much prefer the molded linings from Randy. Either send in your shoes as exchange cores or pay a little extra and buy the shoes with linings molded in place. Randy arches the shoes so that the brake material makes 100% contact against the brake drum right away instead of seating itself gradually as woven linings require.
Marshall
Old 06-13-2023, 04:09 PM   #4
Aretino
Aretino's Avatar
Randy restored my rear brakes to include emergency brake components. Randy does excellent work.
Aretino is offline   Reply With Quote
Old 06-13-2023, 04:38 PM   #5
nkaminar
nkaminar's Avatar
Which stop better?
My friend in Santa Clara says the woven ones squeak. Has that been the experience of the Barners?
Old 06-13-2023, 06:10 PM   #6
mhsprecher
mhsprecher's Avatar
I have had the drums for a few years. I had the hubs installed and the drums turned. I realize that the shoes need to be arched to the drums. As with most projects, it is more complicated than originally thought.
1924 Model T Coupe
1939 Deluxe Fordor
1945 pickup
Old 06-14-2023, 06:05 AM   #7
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Milford, you are very correct. As research towards accurate or authentic restorations have been done over the past decade or so, it is realized just how good original Model-A brakes truly were when they are as they came from the factory. To correctly restore a set of brakes to make them "as good as original" is definitely more complicated than most hobbyists thought, -or think. It honestly requires more jigs, fixtures, and tooling to restore them correctly than most hobbyists have access to.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 06-14-2023, 07:31 AM   #8
Bob Bidonde
Bob Bidonde's Avatar
I tried molded linings, but I am going back to woven linings. The molded linings produce too much brake dust that shows on my Tacoma Cream wheels. Moreover, I find that the woven linings give better panic stopping with my cast iron drums.
Bob Bidonde
Old 06-14-2023, 08:37 AM   #9
Dick Carne
Dick Carne's Avatar
I have had both on our Town Sedan with cast drums. After the first thousand miles the woven linings had essentially glazed over making stopping a real challenge. I’ve since converted to the molded shoes and no longer have issues. Hope this helps.
Dick Carne is offline   Reply With Quote
Old 06-14-2023, 09:43 AM   #10
P.S.
This is a topic in this coming Saturday's video.
The bonded shoes have a lot more grip against the cast iron drums than woven, and I kinda talk about that and show it.
Bonded shoes on stock steel drums don't seem to work as well, so woven appears to be the way to go on steel drums.
P.S. is offline   Reply With Quote
Old 06-14-2023, 11:21 AM   #11
nkaminar
nkaminar's Avatar
Paul, I am looking forward to your video. I get conflicting reports on the two types of shoe linings. Right now I have the molded shoes but I am always interested in alternatives. Some actual engineering quantities, like a coefficient of friction for the two for both new and used, would be nice. But that may be asking too much.
Old 06-14-2023, 05:48 PM   #12
P.S.
OOF! Well, I hadn't really gone into that much detail. Sorry, man. Although I am an engineer, and such things interest me, pretty sure about 99% of my audience would tune out if I went for that much detail.
Old 06-15-2023, 03:18 PM   #13
duke36
Have had some rivets on the woven linings loosen or weren't installed properly.
Gross recommends bonded with their ci drums.
duke36 is offline   Reply With Quote
Old 06-17-2023, 06:58 AM   #14
nkaminar
nkaminar's Avatar
Paul, I guess that puts me in the 1 percent although my bank account doesn't know that.
For future reference, the coefficient of friction can be measured by putting the sample on a piece of cast iron or steel and raising one end until the sample slips. The coefficient of friction is the tangent of the angle when the sample slips. The amount of weight on the sample does not change the physics or math but more weight may change the coefficient of friction.
Old 06-17-2023, 03:53 PM   #15
Patrick L.
Patrick L.'s Avatar
I think you'll prefer the bonded/moulded material with cast drums.
If you feel the need to arc the shoes and have trouble finding a place to do it, I tape sand paper to the drum and 'wiggle' the shoes against the sand paper carefully until full contact is made.
Old 06-17-2023, 09:16 PM   #16
whirnot
whirnot's Avatar
I have three different types on different cars. All with new cast iron drums and a complete brake overhaul. All shoes were arced to the new drums. My roadster has molded linings. My pickup has the original style Woven.
And my Town Sedan has the "soft" woven linings that Berts sells.
All do a good job stopping the Vehicle.
The Original style Woven are a little too grabby in my opinion. They lock up pretty easily. They also squeek the loudest.
The Sedan with the soft woven, also do a great job stopping, are a little quieter. They do squeek once in a while.
The roadster with the molded definitely take the most pedal pressure in a normal situation, even though it is the lightest car. They don't make any Noise.
Personally I like the Soft Woven the best.
In my opinion molded linings do not work better that woven, quite the opposite
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
1931 Coupe
2 Smith Motor Compressors
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 06-17-2023, 10:10 PM   #17
ABento
Now that this discussion is up and running I'll jump in, I'm working on a 34 1 1/2 ton truck with mech brakes and woven linings, it has a soft pedal, doesn't stop and even has a vacume assist booster on it, it'll slow toy down but if it had a load on it you better drag your swamper to stop, everything is adjusted up pretty snug and still not much help, is the bonded lining the answer on this.
ABento is offline   Reply With Quote
Old 06-17-2023, 11:14 PM   #18
Marshall V. Daut
ABento -
Read posting #3 in regards to a soft brake pedal. There's your answer - or at least it was for me.
Marshall
Old 06-18-2023, 09:11 AM   #19
ABento
I read all the posts but a lot of the posters say the woven works better in the steel drums of which is what is on the truck, I had been thinking of going bonded but the brake place I use that has been in business for 50 years or so says the woven is what they use on crane drums and its the best, I wanted to see what you guys thoughts were on this, it is kind of explained from reading the above posts.
Old 06-18-2023, 01:25 PM   #20
ModelA29
ModelA29's Avatar
I wonder if the removal of asbestos from brakes has had an effect of their stopping distance or fade resistance.
ModelA29 is offline   Reply With Quote
