Old 06-07-2023, 05:28 PM   #1
jgriffin
jgriffin's Avatar
Default Tillotson carburetor question
While refreshing a Tillotson Carb and putting it back together I found that the upper pot metal piece is not flat. So when I am putting the 3 screws back together there is a gap large enough to where the gasket will not seal. Any suggestions on how to correct this? If it was the lower piece it looks like it would be easy to sand down flat.
Thanks in advance for any insight!!
jgriffin is offline   Reply With Quote
