Old 06-05-2023, 03:42 PM   #1
GordonP
Default Gunk in gas tank
I'm trying to get a 29 Model A started.
The flow out of the gas tank is minimal. I've removed the shut off valve.
I know the car was parked for a number of years in a hot location, and I suspect gas evaporated leaving something that looks like shellac in the tank.
As far as i know, the tank was never sealed.
The goop around the the threads isn't hard.
Help
Please
GordonP is offline   Reply With Quote
Old 06-05-2023, 03:53 PM   #2
ronn
Default Re: Gunk in gas tank
well Ive had several old As that havent run for awhile and full of crap in the tank
I take a garden hose and fill the tank and let it run for say 45 minutes, the majority of the rubbish comes out. then I take a shop vac and duct tape it to the filler and BLOW
air through the tank with the shutoff valve removed. It is usually dry within an hour. DONT SUCK the air- BLOW.
Then pencil filter, replace valve etc and good to go. If there is still fine rust, then check pencil filter every so often and clean or replace till tank is clean. I also run MMO.
this is the lazy mans method and has worked every time for me.
Old 06-05-2023, 04:44 PM   #3
Richard in Anaheim CA
Richard in Anaheim CA's Avatar
Gordon,
I have cleaned tanks in the car using carburetor cleaner and also phosphoric acid referred to as "metal prep" or generic, and much cheaper,"Driveway cleaner". It is a bit costly because you need to fill the tank about half full and let sit for some time.
The last one I cleaned was much cheaper and worked pretty good. A half tank of E85. Yes,, available at the pump at least in California and somewhat cheaper than gasoline.
I left in a couple of days and shook the car whenever I walked by.
RICHARD
Anaheim CA
Richard in Anaheim CA is offline   Reply With Quote
Old 06-05-2023, 05:59 PM   #4
Gary WA
Gary WA's Avatar
Acetone! shake around leave set for a while! Strain and redo till clean as can be.
www.whidbeymodelaclub.com
Old 06-05-2023, 07:24 PM   #5
GPierce
GPierce's Avatar
Ethanol is a great solvent to get rid of varnish residue from gasoline. Over time E10 will dissolve it but the sticky residue will stop up your fuel filter and carburetor.
GPierce is offline   Reply With Quote
Old 06-05-2023, 07:25 PM   #6
California Travieso
Send a message via Yahoo to California Travieso
Originally Posted by Richard in Anaheim CA View Post
Gordon,
RICHARD
Anaheim CA
Richard,
I assume that the E85 gas dissolved the residue from the old gas that was left in the tank; however, that wouldn’t take care of any rust in the tank. I suppose you could also use 5 gallons of something like Rust911 for the rust.
David Serrano
California Travieso is offline   Reply With Quote
Old 06-05-2023, 10:02 PM   #7
dalton
Get the gunk out - water and/or mineral spirits should do just fine. I used Evaporust in my tank to clear the rust. I bought a 5 gallon bucket of Evaporust. Soaked for a couple of days, then turned the tank upside down and soaked for a couple more days. Now I run ethanol free fuel and have no problems with the fuel tank. Evaporust also does wonders for the cooling system.
dalton is offline   Reply With Quote
Old 06-05-2023, 10:23 PM   #8
Richard,
David Serrano
Yes, that would be more effective but I was looking for a quick cheap way to dissolve the gunk from old CA gas. Some of the rust would be released with the gunk and I rinsed the tank with water and air dried.
Old 06-05-2023, 11:26 PM   #9
oldspert
oldspert's Avatar
My tank was so full of rusty particles when I would poke a stick in the tank it sounded like crushed potato chips. I pulled the tank and flushed it thoroughly with water hose. Flushed out enough rust to cover my drive. Used Rust 911 mixed four gallons and let it sit 24 hours, rotating often. Let it dry. Used Ospho to coat the inside for another 8 hours. Flushed it thoroughly to remove the rest of the residue. Drained and let it dry two days. Re-installed the tank and all seems to be OK.
oldspert is offline   Reply With Quote
Old 06-06-2023, 06:54 AM   #10
Bob Bidonde
Bob Bidonde's Avatar
I am a fan of Acetone as a solvent for your gasoline residue gook. Rebuild the gas gauge with a kit available from parts suppliers. Add a screen into the inlet port of the gas shutoff valve. The screen is also available from suppliers.
Bob Bidonde
Old 06-07-2023, 12:51 AM   #11
Tom Foster
Hi Dalton. ...
A question:
Did you have any problems with the old finish on the outside of the tank? My tank has 1964 nitrocellulose lacquer that is in reasonably good shape and would like to not disturb if possible
Thanks
Fearless
Tom Foster is offline   Reply With Quote
