05-26-2023, 07:34 PM | #1 |
Dash light
The instrument light on the dash of my 29 Tudor has never functioned since I purchased the car. Never bothered me before but now I would really like it to work. My silly issues is, I do not know how to turn it on. Anyone??
05-26-2023, 07:36 PM | #2 |
Re: Dash light
Push and turn clockwise about 1/8 of a turn. Just pushing will turn it on. It will turn off when released unless turned clockwise. Turn counter-clockwise to turn it back off. It takes a #63 6-volt bulb if you are still running 6 volts.
05-26-2023, 07:44 PM | #3 |
Re: Dash light
Thank you so much.I just installed a new wiring harness and have new ambition to make everything work. Thanks
05-28-2023, 01:49 PM | #4 |
Re: Dash light
If you put an LED bulb in it you will have more light, less current draw and it WON'T burn your fingers.
05-28-2023, 02:12 PM | #5 |
Re: Dash light
If you have a modern ignition switch you can wire the light to turn on only with the ignition on. So if forget to turn the light off it will not drain your battery.
05-29-2023, 12:28 PM | #6 |
Re: Dash light
Stickshift 1915 Model T touring 1931 Ford Model AA Flatbed |
05-29-2023, 03:00 PM | #7 |
Re: Dash light
I had a aviation grade light bulb in there. It was the replacement for the #63. It had a heavy duty filament, but it finally burned out. I got it at NAPA. Wish I still had that part number, because the light I have now is not as much candlepower.
05-30-2023, 09:44 AM | #8 |
Re: Dash light
Does the bulb not have a number on it? Possibly a #81, 6 CP compared to a #63, 3 CP.
