Old 05-11-2023, 05:43 PM   #1
Russ/40
Russ/40's Avatar
Default 28 - 29 Pickup top irons
Attached are photos of my main top bow for my RDSTR/PU. On those photos I have marked in near proximity holes of 1/4" diameter that were drilled for whatever reason. Those marks do not indicate the holes for the for side curtains, or for the two buckles that mount the bow to the stanchions. Are any of these 1/4" holes supposed to be there?
Also, if you have restored similar bows, what did you use as filler for the tack rails?
If you enlarge the photos you can see the hole locations as hash marks on the concrete.
Russ/40 is offline   Reply With Quote
Old 05-12-2023, 12:51 AM   #2
Floats
Floats's Avatar
Default Re: 28 - 29 Pickup top irons
No idea.
Chris
Regards
Chris
Cape Town
28 Model A RPU, 29 Chevy Phaeton, 67 E Type FHC, 67 250SL Pagoda, 83 911 SC
Floats is offline   Reply With Quote
Old 05-13-2023, 11:34 PM   #3
Russ/40
Russ/40's Avatar
Bump up, maybe someone will address the question
Old 05-14-2023, 07:02 AM   #4
fundytides
fundytides's Avatar
Mike at Classtique Upholstery suggested leather belting to use for tack strips in the top bows. I haven't tried it yet but plan to on my 31 Roadster before I put the new top on. Has anyone tried this? Mike suggested to wet the leather to make it more pliable for installation.
fundytides is offline   Reply With Quote
Old 05-14-2023, 06:52 PM   #5
29Roadster
29Roadster's Avatar
Hi Russ I have restored several sets of bows and the holes you are referring to are ones that someone has drilled in there. Just weld them up. I have used waterproof interior cardboard cut in strips and slide it in the track with very good results that product will hold your tack nails nicely.It can be purchased by the sheet at any good upholstery shop.
29Roadster is offline   Reply With Quote
