Old 05-11-2023, 08:03 AM   #1
panhead_pete
panhead_pete's Avatar
Default 1933 vs 1934 Crossmembers
Looking at going back to stock factory front shocks. Have done some reading here and it mentions 33s went on the inside and 34s on the outside of the frame rails due to differences in the crossmembers.
Could someone please enlighten me as to how the two crossmembers differ?
Thanks in advance.
Pete
Looking for an unrestored 33 34 3W or 5W coupe.
Thanks
panhead_pete is offline   Reply With Quote
Old 05-11-2023, 08:43 AM   #2
deuce lover
deuce lover's Avatar
Default Re: 1933 vs 1934 Crossmembers
The '33 front cross member curves forward after the motor mount biscuit location.The '34 flares rearward.I discovered that when I went to put new front shocks on my '33 tudor.The cross member had been replaced with a '34. Since I already had the front shocks and arms I simply did some trimming on the housing to get them in on the inside.
Yes I could have mounted them on the outside BUT would need different arms.I also wanted to lower the car by removing 4 leaves of the spring and since It still had mechanical brakes - the rods would have interfered with the shock set up on the outside.
Here is a pic of a 34 front crossmember
deuce lover is offline   Reply With Quote
Old 05-11-2023, 09:19 AM   #3
DavidG
DavidG's Avatar
In the two photos below, the run-of-the-mill '33 front cross member is shown on the left and that for '34 on the right. The front gussets shown in front of the '33 cross member where the radiator attaches differ for '34 as the inner corners extend back to the cross member itself.
There was a short-lived initial version of the '33 cross member that carried over the 12" spacing between the front motor mounts.
Old 05-11-2023, 10:17 AM   #4
Ricosan
Ricosan's Avatar
I’m confused. My ‘33 wagon looks like it has the ‘34 cross member as well as shocks On the outside. Is it because it’s a wagon (truck?)? Does this mean it has a ‘34 frame?
File Type: jpg 613AA33C-AF45-469A-B90F-69E49E79F217.jpg (53.4 KB, 67 views)
File Type: jpg 637640A8-50D5-48DB-AA6D-3EA95DCD455C.jpg (50.0 KB, 69 views)
File Type: jpg F4279D4F-7B33-4A39-AB25-560264DBF3B1.jpg (51.1 KB, 66 views)
Ricosan is offline   Reply With Quote
Old 05-11-2023, 11:02 AM   #5
deuce lover
It appears that your crossmember has been replaced.Its bolted in.Originally they were riveted in.
Old 05-11-2023, 12:12 PM   #6
DavidG
DavidG's Avatar
It's not the least bit uncommon for the '33 front cross member to have been replaced with the stronger '34 version and it is a bit of a challenge to find a good '33 front cross member if you want to return the chassis frame to its original configuration if the cross members were switched.
Old 05-11-2023, 12:18 PM   #7
petehoovie
petehoovie's Avatar
Old 05-11-2023, 01:31 PM   #8
David J
David J's Avatar
pic of a 33 crossmember factory installed.
Pic also shows fender dimple on a 33
The 33 wagon looks to have 34 inner fenders
File Type: jpg 33 FRAME,CROSSMEMBER AND FENDER DIMPLE .jpg (60.4 KB, 321 views)
David J is offline   Reply With Quote
Old 05-11-2023, 01:50 PM   #9
Ricosan
Ricosan's Avatar
I guess I’m not surprised at all.
Richard
Old 05-11-2023, 07:27 PM   #10
panhead_pete
Wow thanks all. REALLY appreciate the info. Makes it much easier to understand.
Thanks
Old 05-11-2023, 07:43 PM   #11
mercman from oz
mercman from oz's Avatar
1933 Ford Front Cross Member - David J
Old 05-11-2023, 07:45 PM   #12
mercman from oz
1934 Ford Front Cross Member -Mercman
Old 05-11-2023, 07:51 PM   #13
mercman from oz
Close-up - 1934 Ford Front Cross Member
Old 05-19-2023, 04:52 AM   #14
panhead_pete
Cheers Mercman!
Thanks
Old 05-19-2023, 07:01 AM   #15
Terry,OH
Terry,OH's Avatar
Pete: The 33 frame has holes for the front shocks to mount inside the frame where the 34 does not. The 33 front and rear shocks have bolt on arms where the 34 front shocks have pressed on arms. The inner fenders are also different to clear the shocks mounted on the outside of the frame, 34. Make sure you get the correct front shocks.
Old 06-09-2023, 12:44 AM   #16
deuce lover
David, Would you have a pic of that early version? I recently purchased these early front motor mounts. Here is a pic of a 33 Ford cutaway chassis.Those early motor mounts are clearly visible.Thanks
Old 06-09-2023, 01:34 AM   #17
mercman from oz
Very Early 1933 Engine Mounts purchased by deuce lover
Old 06-09-2023, 01:42 AM   #18
mercman from oz
1932 Ford V8 Block showing Engine Mounts
Old 06-09-2023, 08:58 AM   #19
Bored&Stroked
Bored&Stroked's Avatar
I'm not sure if anybody is actually rebuilding 33/34 shocks . . . anybody on here know?
Old 06-09-2023, 09:20 AM   #20
deuce lover
Yes,Andy Falandes in MA,https://www.google.com/url?sa=t&rct=...YmdzwtoiYHpEkB
I just got a pair outright and shipped to France.Absolutely the best.No need to go anywhere else.
Plus he answers the phone.
