Old 05-08-2023, 04:37 PM   #1
ModelA29
ModelA29's Avatar
Default Vortex intake
Anyone have a spare Vortex intake? I like the dual updraft idea. No electric fuel pump required.
I'd use a bigger cam and aluminum head to run with it.
Any pointers from anyone running one?
ModelA29 is offline   Reply With Quote
Old 05-08-2023, 05:35 PM   #2
jack backer
Default Re: Vortex intake
Two updrafts better than one updraft. One downdraft better than two updrafts
If you going to run dual updrafts use marvel schebler/ all state carburetors,,
Instead of the jets a zenith has it uses an emulsion tube design.. simple and effective
jack backer is offline   Reply With Quote
Old 05-10-2023, 03:58 PM   #3
Sparky
Sparky's Avatar
I don't have a spare one, sorry. I have been running one for several years with two Model B zenith carbs. It runs great but does take a bit longer to warm up than the stock single carb. Unfortunately, I believe Charlie Yapp has stopped making them.
Sparky is offline   Reply With Quote
Old 05-12-2023, 10:50 AM   #4
Jim Brierley
Not running one but you are going in the right direction for adding power. Bigger, or multiple, carbs, and higher compression are the two easiest and quickest ways to increase power on our A's. Be careful on going to a bigger cam, too much is worse than stock. (and I grind cams)
Jim Brierley is offline   Reply With Quote
