#1 |
I'm restoring my '46 Mercury horns... it has the earlier style trumpet horns mounted on the inner fender on the driver's side. When I stripped back the original cloth loom over the wires to the horn relay at the horn mounting bracket, I was surprised to see what looks like a jumper wire soldered across the two posts (across the heavier gage yellow wire and smaller gage blue/yellow tracer wire from horn button). Third post on the relay has two clips for wires sending power "out" to energize the horns. I'm pretty sure that all the wiring was original. That jumper makes no sense to me. And the horns worked when the car was last driven before I stored it.
I'm not an expert on electrical wiring, but I was expecting 6V negative (yellow wire) into the relay, along with the blue/yellow tracer wire from the horn button, and then the two wires out of the relay to the horns. I thought when you pushed the horn button, you grounded it and completed the circuit to energize the relay and send current to the horns. It seems to me that the jumper wire would mess that all up. Any ideas how this is supposed to work? Thanks in advance. Last edited by Bruce_MO; 04-16-2023 at 07:27 PM. Reason: Photos added |
#2 | |
Does this image, complements of Mac VanPelt, help you any? It's 46-48 FORD, but likely the same as Merc. Coop |
#3 |
I wonder if someone bypassed the relay because they wanted to use another switch setup, maybe because the relay failed or something.
#4 |
Coop,
Thanks for posting the schematic. I had seen it, but it’s unclear if there’s a jumper wire. I just hooked up a 6V battery charger to it and it works fine. I can hear the relay click and the horn works, so I guess the jumper wire will stay in place. Thanks Bruce |
#5 |
I am real curious about this. The horn relay has 3 terminals, right?
One is the coil (-) that connects to the battery negative. One is the other side of the coil which is grounded when horn button is pushed. One is one side of the relay contact that connects to the horns. The other side of the relay contact connects to the battery side of the coil internally to the relay. So here are the jumper possibilities (I arbitrarily numbered the terminals): 1-2 fuse will blow as soon as horn button is pushed 2-3 fuse will blow as soon as horn button is pushed 1-3 horn will blow continuously regardless of button So the only configuration that will work is 1-3 with a modification to the car horn button to supply 6V when the horn button is pushed rather than providing ground to the coil. But, the reason for the horn relay is to handle relatively high current which would cook the contacts of the horn button so there would need to be a higher current button or another relay. |
#6 |
#7 |
#8 |
Ford horns from that era have so connection to the ignition switch. They will sound anytime the horn switch is actuated. The relay is placed very close to the battery to get the greatest amount of amperage to the horns. They draw a lot of current.
#9 |
I am encountering the same, but I see my jumper is broken. I believe it is a resistor wire to limit the current though coil of the relay. Hunt is on for a resistor wire or a unit with the wires. It seems to be a 50-ohm value in 6-inches of length. Not shown in any wiring diagrams I have searched.
#10 |
I found the only picture concerning the resistive wire jumper. A resistor symbol by the horn relay is shown. It says it is for a Lincoln.
#11 |
#12 |
#13 |
I have now been educated on the purpose of the resistive wire. It is used to prevent a shock when pressing your horn ring. It is interesting to be able to find this information. An article from June 25, 2015, of Old Cars has a great write up on this issue. I am unable to download it here. Bulletin is from a 1946 Ford guru who is helping me with my car.
#14 |
There should not be a jumper wire. You are correct. The thicker yellow wire is the power wire. The other wire is from the horn button and acts as a ground to the relay. The whole unit gets a ground thru the fender. I just restored my horn assy. if you have any other questions.
#15 | |
#16 |
" petehoovie" & "Shortdoor" are right on! When I removed the horn harness and "Sea Shell" horns from my 1948 Lincoln Continental Coupe, this very fine coiled wire fell away- it was toast! The '47-'48 LC wiring schematic explained it.
