04-16-2023, 01:22 PM | #1 |
1940 mercury front fender aprons to frame fasteners
How are the front fender aprons attached to the frame. It looked like there was a rubber bumper holding them on when I removed them. Is that correct and if so where can a buy some. I can't find anything on third generation auto's website
04-19-2023, 11:22 AM | #2 |
Re: 1940 mercury front fender aprons to frame fasteners
Try this again
04-19-2023, 11:27 AM | #3 |
I have a 39 Mercury I can look at tonight BUT I don't recall any "rubber" grommets or bumpers you speak of
04-20-2023, 01:23 PM | #4 |
04-20-2023, 01:33 PM | #5 |
If they are like to the Ford the rubber bumpers are at the bottom of the panel next to the frame. They are there to stop the panel from rattling against the frame.
04-20-2023, 04:39 PM | #6 | |
My '41 Merc uses the same bumpers at the panel bottom. When old and hard they really rattle. I used some like these... https://cgfordparts.com/upper-door-b...7023020-b.html Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick) '41 Merc Town Sedan / 260" 8CM engine '66 Fairlane four door / "warmed up" 302 Last edited by cadillac512; 04-20-2023 at 04:50 PM. |
04-21-2023, 08:34 AM | #7 | |
In early '39, the inner aprons had a 90° bracket at the very front that was fastened to the top of the frame rail. By 1940, the two places at the brake hose opening had rubber bumpers as described in a previous thread. In early '39, two hex head bolts were installed through the apron and on into the frame in this area. Shortly thereafter, this was reduced to one bolt and shortly after that, no bolts, just the rubber bumpers. A 1940 Ford had a cross brace near the front that fastened to the aprons. I'm not certain how Mercury dealt with that area.
04-21-2023, 06:05 PM | #8 |
Sorry for the delay and hope what i shot helps. Mine is a very early 39 so most likely a lot change by the time 40’s got the line
04-22-2023, 05:39 PM | #9 |
Thank you everyone...
