Old 04-12-2023, 02:14 PM   #1
chuck stevens
chuck stevens's Avatar
Default grease your u-joint
Now is the time to grease all those hard to get to fittings. I just finished replacing the driveshaft u-joint in my 47, what a job!! I know its one of those fittings we tend to forget but a tube of JD cornhead grease and a minute or two is much easer than than what I just went through. Not fun.
chuck stevens is offline   Reply With Quote
Old 04-12-2023, 02:45 PM   #2
34fordy
34fordy's Avatar
Default Re: grease your u-joint
What were the symptoms Chuck?
34fordy is offline   Reply With Quote
Old 04-13-2023, 06:18 AM   #3
chuck stevens
vibration, a clunking noise when using reverse, sometimes it only vibrates when you let off on the gas. If it breaks at road speed be sure you are wearing good sneakers and know someone with a trailer.
Old 04-18-2023, 12:30 PM   #4
srfnken
Yes this is a pain in the butt to get to, but if you dont there will be problems. Thanks for the reminder
srfnken is offline   Reply With Quote
