Old 04-11-2023, 11:07 PM   #1
B-ster
Default Oil galley, distributor gear oiler
Can someone please get me the part number for the oil galley plug with the star pattern holes in it that oils the distributor gear. I can't find it in the manual. The one that was in my engine when I got it rebuilt is sticking out too far and preventing me from installing the distributor. I tried grinding the back of it so it would give me more room but it is going in just about two turns, still hitting the gear. I don't know if it's the correct part or not. It's 1/2" with size 20 threads. It is currently 1/4" long and I believe needs to be flush with the block. I'm really confused and aggravated. I think it may need to be tapered in the rear so it can go in further.
B-ster is offline   Reply With Quote
Old 04-13-2023, 08:51 AM   #2
GLAmes
GLAmes's Avatar
Default Re: Oil galley, distributor gear oiler
What engine are you working on? I have a couple junk 239s in the scrap pile and don't see the plug you are looking for.
'54 Skyliner. As close to original as I could restore it to.
GLAmes is offline   Reply With Quote
Old 04-13-2023, 11:33 AM   #3
B-ster
It's Lincoln 317 y block. The plug is just above the distributor gear in the oil galley
Old 04-13-2023, 12:13 PM   #4
dmsfrr
dmsfrr's Avatar
Fyi, the 'Ford' version of a Y-block doesn't have a plug there.
photo 1
Looking down thru the opening in the block for the distributor housing & shaft.
photo 2
The machined ledge the driven distributor shaft gear spins on, and the area behind it,
looking down from the center rear of the lifter valley.
dmsfrr is offline   Reply With Quote
Old 04-14-2023, 01:25 PM   #5
Ole Don
Ole Don's Avatar
I think you may have to make one.
Ole Don is offline   Reply With Quote
Old 04-14-2023, 02:13 PM   #6
KULTULZ
KULTULZ's Avatar
Question Re: Oil galley, distributor gear oiler
Originally Posted by KULTULZ View Post
Are you saying the DIST slides in now?
Originally Posted by B-ster View Post
Yes. It slides in. I posted that a few posts ago.
SOURCE - https://www.fordbarn.com/forum/newre...eply&p=2218565
I think he is beyond this mystery. I can't figure it out.
"Last Sunday, I caught him makin' eyes at Idell Bushey durin' preachin'. And I know what they do up there in the hills when they say they're possum huntin'. They're just sittin' around the campfire, drinkin' hard cider, hittin' each other on the shoulder and hollerin' 'flinch!'."
― Charlene Darling (Daughter of Briscoe Darling)
KULTULZ is offline   Reply With Quote
