04-10-2023, 08:44 PM | #1 |
Tire tubes
Anyone have experience with which supplier has the best quality tire tubes. Your opinions are appreciated . Thank you.
04-10-2023, 09:53 PM | #2 |
Re: Tire tubes
I've bought mine from Bert's for years. No problems.
04-10-2023, 10:49 PM | #3 |
Re: Tire tubes
About 10 years ago, tubes were ALL crap but I think that when people complained enough and stopped buying them if they could, vendors got their act together. I think Brattons was the first to have them made again from virgin materials. Recycling is fine - in its place but not for tubes. Nowadays, I think all of the vendors have pretty good tubes.
04-11-2023, 12:24 AM | #4 |
Re: Tire tubes
Around November 2022 I bought four inner tubes from Brattons. The tube wrapper said made from 100% new rubber. They're still maintaining the 38 lbs inflation.
04-11-2023, 05:19 AM | #5 |
Re: Tire tubes
Tubes for radial tires are thicker and will hold up longer. They are better able to take the flexing of radial tires but are also stronger in bias ply tires.
04-12-2023, 08:54 PM | #6 |
Re: Tire tubes
04-13-2023, 07:21 AM | #7 |
Re: Tire tubes
70 year old tube? I’d be skeptical
04-13-2023, 08:02 AM | #8 |
Re: Tire tubes
I was buying these off of ebay
2 for 30. I see they are now 32. Heavy duty and vet owned business.......... TWO 4.00-19 Farm Tractor Tire Inner Tubes Some Ford 8N 9N Heavy Duty |
04-13-2023, 09:54 AM | #9 |
Re: Tire tubes
I appreciate all your replies ! Thank you !
04-13-2023, 10:34 AM | #10 |
Re: Tire tubes
Tubes should be stored partially inflated, if left folded they tend to crack at the corners where they're folded.
