Old 04-04-2023, 05:44 PM   #1
dschwartz
Default c4 transmission
I have c4 transmission bolted to a 59ab. Need to know what is best way for selector linkage.
Thank you
dschwartz is offline   Reply With Quote
Old 04-04-2023, 07:13 PM   #2
paul2748
paul2748's Avatar
Default Re: c4 transmission
Going with a floor shift ? If so, if you don't mind the look the Mustang shifters will work.
C4's come in two variations regarding shifters - floor shift or column shift. The floor shit ones have the arm coming out the of the trans in an up position, the column shifter ones the arm points down. Depending on the year of the trans, it may have an arm that points up and down. I have one of those, it is an 1980 unit.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 04-04-2023, 09:40 PM   #3
TravisDM
Okay, I will mention the Mustang shifters to my uncle. He'll work on this C4 trans once we installed the rotors and tis wheels on the truck and clear the garage.
TravisDM is offline   Reply With Quote
Old 04-04-2023, 11:57 PM   #4
tubman
tubman's Avatar
Either you posted the wrong link or you're kidding us about the wheels, right?
Old 04-05-2023, 11:13 AM   #5
blucar
blucar's Avatar
I would think that the best shifting setup for the C4 in a '40 would be to utilize the original column shift. Since the '40's did not have the shift shaft incorporated into the column it would be fairly simple to fabricate a gear selection indicator onto the column or to use an electric after market selector. I have an automatic trans in my '39 convt, I upgraded the column to a late model GM (90's) because I wanted turn/hazard lights built into the column.
Bill.... 36 5 win cpe
Old 04-05-2023, 01:12 PM   #6
5851a
Whatever type of shifter used it needs positive safety detents. The transmission detents alone are not enough.
5851a is offline   Reply With Quote
Old 04-05-2023, 02:54 PM   #7
Ol' Ron
Ol' Ron's Avatar
I ran one behind a stock 51 Merc engine in a 47 KB=1 int for about 5 years. No problems. Had a 3.3 merc rear from the 51 merc
still have it and the KB1
Gramps
Old 04-05-2023, 03:00 PM   #8
TJ
TJ's Avatar
Thank you
Dan, if you are putting it in a '40 use the stuff from Limeworks. Their setup also is made for the neutral safety switch. If you want to see one send me a PM with your e-mail and I can send you some photos of the linkage. Tom
Old 04-05-2023, 07:57 PM   #9
paul2748
paul2748's Avatar
All C4's I have seen have the neutral safety switch bolted to the side if the trans and is activated by the shifter rod.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 04-05-2023, 10:20 PM   #10
fordor41
fordor41's Avatar
I attached a rod to our C-4 from the 2-3 shifter lever on the stock column. problem with ours was it was a '80 floor shift so I had to make a bellcrank off the side of the bell housing to get park in correct position otherwise park would have been down and low was up on the shift lever(backwards). I've heard you can pull the pan and reverse the shifter shaft but I didn't want to get into the trans.
fordor41 is offline   Reply With Quote
