Old 03-17-2023, 11:01 AM   #1
Dennisfly
Dennisfly's Avatar
Default Adjusting Anti-Chatter Rods
35 Tudor Sedan. Depending on my clutch technique, I sometimes have some minor chatter when starting out, more so in reverse. A friend suggested that I need to adjust the ant-chatter rods. I looked at the rods and they appear to be fixed with an eyelet at the rear X frame adjustment and at the front they attach to the bell housing with a ridge on the rod and a castellated nut. I don't see any accommodation for an adjustment. They don't appear to be loose. Am I missing something?
1929 Town Sedan (Briggs) 155B, Mitchell Overdrive
1935 Model 48 Tudor
Dennisfly is offline   Reply With Quote
Old 03-17-2023, 11:24 AM   #2
Seth Swoboda
Seth Swoboda's Avatar
Default Re: Adjusting Anti-Chatter Rods
Some minor clutch chatter might be normal. What is the condition of your clutch and flywheel surface? Do you have hot spots on your flywheel surface? Does the clutch disk have oil on it?
Seth Swoboda is offline   Reply With Quote
Old 03-17-2023, 01:15 PM   #3
V8COOPMAN
V8COOPMAN's Avatar
Dennis .... There is no specific adjustment, as such, but they certainly can be adjusted to hold different, directional tension on the engine/trans assembly. I'll show the stock type set-up BELOW, just for general principles. The second picture is actually a NON-STOCK set-up shown on an 8BA engine which was put into an earlier chassis. The second set-up shows more-clearly how you could possibly bias the tension in one direction or the other, or pre-load the engine/trans assembly in one direction or another.
The second picture shows how you could pre-load the rods to push (or pull) against the stops using the two lock nuts on either side of engine. Not sure it would do any good, though. I've never played with this situation.
As Seth noted in post #2, a lot of times what you have is caused by a yucky flywheel surface.
Coop
Click Links Below __
T5 W/TORQUE TUBE
Old 03-17-2023, 01:16 PM   #4
Kube
Super Moderator
Kube's Avatar
There is no adjustment on a stock rod. TIGHT is the proper "torque".
Old 03-17-2023, 02:17 PM   #5
T Scott
Since it looks like you will be pulling the transmission to access the clutch and flywheel, I would check the u joint for wear. Excessive play in the driveline can also contribute to chatter.
T Scott is offline   Reply With Quote
Old 03-17-2023, 02:34 PM   #6
tubman
tubman's Avatar
Also, check the motor and transmission mounts. I know it's not quite the same, but when I had a chatter problem in my '51 about 20 years ago, I had the flywheel resurfaced and installed a new pressure plate and disc. It didn't help much. Replacing the motor mounts made it smooth as silk.
Old 03-17-2023, 02:41 PM   #7
JayChicago
JayChicago's Avatar
I found I can reduce clutch chatter by changing my driving habits. Learned to engage the clutch quicker than with other cars. Flatheads have lots of low-end torque; it's harder to stall a flathead. I learned to keep the RPMs down until clutch is engaged, then give it gas.
Also, I have read that old stiff engine mounts (or loose mounts) can exacerbate clutch chatter.
JayChicago is offline   Reply With Quote
Old 03-17-2023, 03:21 PM   #8
FlatheadTed
FlatheadTed's Avatar
Here's a shot of a clutch you see the three arms they need to be in perfect adjustment .A lot of aftermarket clutches (non Ford ) use very low grade iron on these arms result rapid ware on the pivots , they are not lubed so quality is essential ,Ted
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 03-17-2023, 03:30 PM   #9
Lawson Cox
Lawson Cox's Avatar
Ted has the CORRECT solution.
Old 03-17-2023, 04:47 PM   #10
tubman
tubman's Avatar
Check out this tread about clutch "fingers" : https://www.fordbarn.com/forum/showt...highlight=shim.
Old 03-17-2023, 08:27 PM   #11
Dennisfly
Dennisfly's Avatar
Thank you all for your responses. My rods are as depicted in Coop's first picture - stock and properly fastened. I think my technique is part of it, as it happens most often when starting up hill or when the clutch is slipped more. It's not horrible but I thought I would investigate. The front motor mounts appear tight but with some age checking in the rubber. The transmission support is dirty and hard to see clearly, but I suspect it is the same age as the front mounts. At this point it is not serious enough to pull the transmission but, when and if that day comes, I will carefully inspect the flywheel, clutch plate, pressure plate, finger heights, bearings, and mounts. My education continues!
1935 Model 48 Tudor
Old 03-18-2023, 10:26 AM   #12
deuce_roadster
deuce_roadster's Avatar
Too soft motor and trans mounts can also contribute to chatter, cinch them down tight. As Kube said, the engine stay rods need to be tight.
Old 03-18-2023, 03:44 PM   #13
farmertom
farmertom's Avatar
if transmission mounts are had to see from alot of oil and crud probably mount pucks are spongy. you know what constant oil soaked rubber is like. some time i shopuld check mine now that i'm reminded. iv'e had to adjust my accelerator/clutch action at times aswell. iv'e gotten a little more tension on the stay rods last spring. thought about installing new mounts on eng. and trans. i would assume motor and trans tail need to be jacked up together? Tom.
farmertom is offline   Reply With Quote
Old 03-19-2023, 12:50 PM   #14
deuce_roadster
I would think you could loosen all 4 engine and trans mount bolts, even take nuts off one end, and replace that ends mounts, reinstall bolts and nut but leave loose, then replace the other end, and when all 4 have mounts have been swapped out, chinch them down. Shouldn't have to raise either end up too much.
Old 03-19-2023, 01:48 PM   #15
blucar
blucar's Avatar
An old time service trick that was performed on vintage vehicles to minimize/eliminate clutch chatter, generally the result of oil on the clutch, was to pull the vehicle up to a telephone pole with the front bumper touching the pole, then with the trans in high gear slowly accelerate the engine as the clutch was slowly released. When the slipping clutch started to lightly smoke, fully disengage the clutch.
Of course the procedure was noted on the service ticket as 'adjust clutch'.
Been there done that!!
Bill.... 36 5 win cpe
Old 03-19-2023, 05:33 PM   #16
tubman
tubman's Avatar
Actually, when I had the problem with my '51, this was the first thing I tried, I now believe it's an "old wives tale" that has no credibility. I would concentrate on the motor and transmission mounts.
Old 03-21-2023, 12:09 PM   #17
blucar
blucar's Avatar
Like many of the old-time 'shade-tree mechanic fixes', slipping the clutch against a telephone pole/tree solved nothing, which generally put a band-aid on the the real problem.
Old 01-04-2026, 02:52 PM   #18
Fredy Decker
Fredy Decker's Avatar
I want to temporarily remove the anti chatter rods on my 1940 for cleaning and repainting however they are attached to the frame with FEMALE square headed bolts. A 3/8" ratchet is to big and a 1/4" is too small. Any advise?
Fredy Decker is offline   Reply With Quote
Old 01-04-2026, 03:10 PM   #19
glennpm
glennpm's Avatar
Sacrifice a 3/8" short extension or 1/2" to 3/8" adapter. Measure the hole and grind the 3/8" extension or adapter to fit. Now you have a new tool for your box :-)
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
Old 01-04-2026, 04:10 PM   #20
deuce lover
deuce lover's Avatar
I believe it is a 5/16 " square opening.
deuce lover is offline   Reply With Quote
