03-07-2023, 05:14 PM | #1 |
Sheet metal sources suggestions
Firewalls, floor pans, patch panels, all that stuff. I haven't bought anything in a while, I see Howell's is still around, selection seems more limited than in the past though. Does anyone have any other good sources?
Thx! |
03-07-2023, 05:17 PM | #2 |
Re: Sheet metal sources suggestions
For What?
03-07-2023, 07:43 PM | #3 |
Don’t go direct to Howell, you’ll be sorry
Tom Bays stuff is very average Bradley floor pans are good….if you can get them to respond!! It’s a jungle out there!!! Supply chain still sucks |
03-07-2023, 08:17 PM | #4 | |
As said above, Don't buy directly from Howells. The safest way to deal with them is to buy from one of their stocking dealers or through eBay. If they actually have it in stock they will usually have a eBay listing for it |
03-07-2023, 08:37 PM | #5 |
Everything I have ever bought from Howell's sheetmetal was junk, and did not fit, not even close. I would not waste my money there. I would try Snyders and Brattons's for model A stuff. Even the overpriced stuff at Brookville did not fit very well.
03-07-2023, 09:21 PM | #6 |
03-07-2023, 09:38 PM | #7 |
19 and 49 F1 - jes' like Henry II built 1946 Deluxe - as Henry built it |
03-07-2023, 09:53 PM | #8 |
MEMBER EMERITUS
39/40 floor pans United Pacific.
03-08-2023, 03:14 AM | #9 |
34fordy, I don't mind "tweaking" sheetmetal parts a little to make them fit, but when they are not even close enough to do that, or the compound curves are not even there, they end up in a corner. can't send them back, as it cost more than the parts are worth. freight to and from Alaska has always been high, but now it is ridiculous .
03-08-2023, 04:49 AM | #10 |
final answer- if youre unhappy, make them yourself.
easy answer, buy original parts from places like Berts and on the swap here. dont complain about pricing........ |
03-08-2023, 07:15 AM | #11 |
I’ve found united pacific stuff very good. But very limited as to body styles/years.
Ronn….I’ve never inquired of Steve but does Bert’s have V8 parts?? And, most are not blessed with a sheet metal shop to make panels themselves. Alaska Jim….in Model A, Ahooga (long gone) made parts that required little modification to fit. Last edited by Oldbluoval; 03-08-2023 at 07:40 AM. |
03-08-2023, 07:37 PM | #12 |
I have several different early Fords 35 - 40, all could use a little nip and tuck here and there. So the question isn't so much car specific or part specific. I'm looking more for good sources in general. I guess the most urgent need right now is a small block firewall for a 35 5 window, so I'm going to call around to some of these suggested and see what's out there.
03-08-2023, 08:39 PM | #13 |
I have some 1/2 and full length Bradley pans for ‘39/‘40’s. These belong to an elderly friend of mine who no longer restores cars. They have been in storage for years and I don’t think are available.
03-08-2023, 09:14 PM | #14 |
Give Absolute Sheet Metal in Chino Valley AZ. a call 928-420-1254 Excellent quality replacement and hot rod sheet metal.
03-09-2023, 08:45 PM | #15 |
I have never had a problem with Howell's. One time the FedEx guy left a pair of running boards on the ground in front of my garage. Naturally when I backed out I ran over them. I tried to get fedex to cover it but they put it on Howell's.Howell's sent me a new pair. I bought wheel wells from them. they were great.
03-10-2023, 02:09 PM | #16 |
It seems like the quality and fitment of Howell's parts can really vary. It'd be nice if they indicated which are ones they produce and for which they are merely resellers. That might give some insight into whether a part is likely to fit or only be fit for a scrap bin.
WTB '33 Ford parts: * Sedan/Victoria front seat adjuster mechanism * Sedan/Victoria rear seat catch pieces (B-192921 and B-192964) * Sedan or Victoria roof tack strip (OEM or aftermarket) * Straight commercial (pickup) bumper '33/'34 or '35 (46-17757 or 68-17757) |
03-10-2023, 03:47 PM | #17 |
I will admit that the sheetmetal I bought from Howells, was over 10 years ago. the parts are still over in the junk pile waiting to be made into some kind of patch panel for who knows what. maybe the quality has improved since then
03-10-2023, 04:18 PM | #18 |
Krylon32 & 49'er
I'm trying to wrap my head around complaining about a part made for a car for something for which it was not originally designed I.E. "SBC in a 35"......Think about that for a minute!!!! Especially engine placement and having to modify everything involved to get it into the frame.....The likely hood of every single person getting the engine in the same exact spot in the frame....THEN......making a part for that purpose........Stepping on a roach on the kitchen floor when you turn the light on at night when you are drunk comes to mind!!! Lol |
03-10-2023, 04:28 PM | #19 |
I gave up on reproduction sheet metal that didn't require hours and hours and hours of reworking. Instead I found a very good fabricator locally that will just make it or repair it for you correctly.
03-10-2023, 04:49 PM | #20 | |
