03-04-2023, 08:28 AM | #1 |
1930 Standard Roadster top iron wood
Anyone know where to get top iron wood kit for a 1930 Standard Roadster? I've checked multiple vendors without ant success.
Thanks |
03-04-2023, 08:42 AM | #2 |
Re: 1930 Standard Roadster top iron wood
Ive bought pre bent bows from the Amish in PA in the past. try a google. very reasonable.....
03-04-2023, 08:47 AM | #3 |
Buggy Top Bow
BUGGY TOP BOW ITEM CODE: TBB001 $31.95 (NO REVIEWS YET) LEAVE A REVIEW Replacement bent wood top bows for folding buggy and surrey tops. Width: Required Choose Options DECREASE QUANTITY: 1 INCREASE QUANTITY: ADD TO WISHLIST SHARE: DESCRIPTION SPECIFICATIONS These hardwood bows come in sizes between 38" to 58" in 2" increments (measure from outside of bow to outside of bow). These are bent from stock that is 1 1/4" x 1" and the ends are left long (lengths vary depending on size but are usually around 16 - 26"). They are left unfinished so they may be custom fitted, shaped and cut to length during the top assembly process. ***Legs will be cut down as necessary to make shipping more economical - SPECIFY in the order notes if you have a required leg length*** Hansen............ |
03-06-2023, 10:18 AM | #4 |
