Old 02-26-2023, 03:28 PM   #1
Uncle Bob
Uncle Bob's Avatar
Default Radiator splash apron 1932 question
I guess I've led a sheltered life. The only '32 splash aprons I recall seeing were slightly V'd from flat, but I must admit I don't often look very closely. I just got a new to me '32 sedan and it has a "bubble" in the center portion of the apron. It's a B not a V8; is that the difference? Or something else?
Luck occurs when preparation and opportunity converge.
Uncle Bob is offline   Reply With Quote
Old 02-26-2023, 03:32 PM   #2
petehoovie
petehoovie's Avatar
Default Re: Radiator splash apron 1932 question
Old 02-26-2023, 03:59 PM   #3
Newc
Newc's Avatar
That would have fit my B pickup better than the v'd repros. Newc
Old 02-26-2023, 05:00 PM   #4
DavidG
DavidG's Avatar
B or V8, no '32 was built with an apron shaped like the one in your photo. That must have been a bit of a challenge to create given the lips on the apron at the top and bottom.
Old 02-26-2023, 07:24 PM   #5
Uncle Bob
Uncle Bob's Avatar
Well David, I had thought you might dazzle me with some nugget that this was a rare early production idea that faded away. Your comment about the rolled lip, and my need to do other further inspection underneath, caused me to look at it from another angle. Pic below, my guess now is that it was center punched on an obstruction of some sort down very low with minimal damage to the rolled lip, but looking at the gap to the pad that separates the the bottom of the rad shell the "bubble" is the result of the shield being bent back. It's only about an inch from the axle. The side buckles though are so uniform it's uncanny.................really looks like a stamping outcome.
I will say there is some beauty to the underside of the of this car. No evidence of repair and the frame rails have absolutely no pitting wherever accessible. I'm not going to remove anything that would allow inspection under the webbing where there must be some deterioration, but for what can be accessed it's really nice.
Old 02-26-2023, 09:10 PM   #6
DavidG
DavidG's Avatar
Clearly man made, but in the unintentional sense of the word. Fortunately whatever the car ran into was low enough that it missed the radiator shell itself. It is uncanny that the impact was dead center. In the right hands, it is definitely repairable.
Old 02-26-2023, 09:56 PM   #7
petehoovie
petehoovie's Avatar
