Old 02-26-2023, 09:42 AM   #1
cbabek
cbabek's Avatar
Default 36 flat top coil condenser
I have been having a hard time finding a late 36 flat top coil condenser. - I bought a 37 to 40 with the ground strap soldered to the side of the body and de-soldered it and resoldered it to the but end like the original.
a couple of questions :
- can/ should you solder on a condenser ? if so how hot ?
- these aftermarket condensers seem like junk - should the center screw
terminal be able to spin - I would bet "NO" - right out of the box -
spinning
- Does anyone have a good setup for these flat top distributors for a high quality condenser ?
i was told to talk to Tubman - but I cant PM him ! - I dont have enough posts
appreciate the help
Chris
cbabek is offline   Reply With Quote
Old 02-26-2023, 11:47 AM   #2
Terry,OH
Terry,OH's Avatar
Default Re: 36 flat top coil condenser
Yes it is possible to solder a ground to the body of the condenser as you have done in your photo. Do clean the plating off the body before soldering. No the center screw terminal should not turn if it does the condenser is bad.
Old 02-26-2023, 05:51 PM   #3
cbabek
cbabek's Avatar
Thanks Terry,
this one has the spinnning terminal and wont register any Micro Farad's - but I will try with one of the NAPA IH 200 's I have ordered.
hoperfully I will get a solid reliable condenser and a "stock" appearance.
Chris
Old 02-27-2023, 06:49 PM   #4
fordyford
fordyford's Avatar
If you want a correct condenser, I have them NOS # 68-12300 for the flat top 1936 coils. Made in the USA 40 years ago.
They have been tested on a SUN condenser tester.
Keith
fordyford is offline   Reply With Quote
Old 03-03-2023, 04:36 PM   #5
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
I just foind a bag of good used vertex magneto condensors at .036 mfds ... send me you address and i will donate a few to your project ( have them new for 32 each) I have never seen a bad vertex condensor !!! you just use your oem mount and slip the vertex into case and solder the very last condensor you will ever need .........
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
