Old 01-26-2023, 09:07 AM   #1
cederholm
cederholm's Avatar
Default Spark plug adapter
I need an adapter for my compression tester to fit the larger sparkplug holes. Can any one tell me the specs that I need to look for?
A google search provide the wrong spec and I ended up buying one the doesn't fit. ...should have asked you guys first.
Thanks!
cederholm is offline   Reply With Quote
Old 01-26-2023, 09:13 AM   #2
Y-Blockhead
Y-Blockhead's Avatar
Default Re: Spark plug adapter
Snyders has a spark plug adapter that I use with my Snap-On compression tester. https://www.snydersantiqueauto.com/s...ht=a-12405-adp But like numerous things these days, I see they are "Temporarily Out of stock".
Old 01-26-2023, 09:34 AM   #3
ArtimusGordon
I punch out the porcelain center of an OLD spark plug. I us a compression tester with a rubber tip.
ArtimusGordon is offline   Reply With Quote
Old 01-26-2023, 09:42 AM   #4
alexiskai
alexiskai's Avatar
Bert's claims to have them.
https://modelastore.com/index.php?ro...oduct_id=12635
Old 01-26-2023, 10:08 AM   #5
cederholm
cederholm's Avatar
Good idea - if I had an old sparkplug. I'll keep that in mind.
Old 01-26-2023, 10:08 AM   #6
cederholm
cederholm's Avatar
Thanks all - but does anyone know the size/thread of the hole?
Old 01-26-2023, 10:18 AM   #7
katy
katy's Avatar
7/8"-18
