Old 01-25-2023, 08:11 PM   #1
Old Henry
Old Henry's Avatar
Default 47 outer door handle sagging
How do you fix a sagging outer door handle on a 47 Sedan?
Old 01-25-2023, 08:19 PM   #2
millersgarage
millersgarage's Avatar
Default Re: 47 outer door handle sagging
replace the springs in the mechanism
millersgarage is offline   Reply With Quote
Old 01-25-2023, 08:21 PM   #3
Old Henry
Old Henry's Avatar
I just bought a new handle hoping the bad spring was within it but it is not. Is it inside the door?
Old 01-25-2023, 08:33 PM   #4
Kurt in NJ
Kurt in NJ's Avatar
a new latch sometimes is cheaper than springs, troll ebay, i got new latches for my 36 for 35$ shipped,
the square hole gets worn, one of the fixes was to twist the square shaft of the handle
Old 01-25-2023, 08:38 PM   #5
69a
You can just twist it upwards by hand until it sits level when you release it. I did it with mine over 30 years ago.
69a is offline   Reply With Quote
Old 01-25-2023, 08:38 PM   #6
Zeke3
Zeke3's Avatar
I replaced the latch mechanism to repair a droopy handle on my 1937 car. Originally, i planned to replace the spring in the latch mechanism, but I found the whole latch and it was easy to change.
Zeke3 is offline   Reply With Quote
Old 01-25-2023, 08:57 PM   #7
woodiewagon46
Do not try to bend the stem of the handle to correct the sag. Fix it the correct way and replace the spring. Springs are available and it's a fairly easy replacement.
woodiewagon46 is offline   Reply With Quote
Old 01-25-2023, 09:11 PM   #8
Old Henry
Old Henry's Avatar
I understand now that the problem is in the latch mechanism. I would happily replace the entire mechanism but there are no such latches available anywhere that I could find. As I study the mechanism, it is not made so that the handle spring can be accessed and replaced by any non-destructive action. (The main latch spring is readily replaceable and I've done that before.) Neither have I found whatever spring would go in there if I were to cut into the thing. [Correction. Dennis Carpenter has it. I'll order it and see if I can figure out how to put it in.]
Old 01-25-2023, 09:24 PM   #9
mcgarrett
The best way to fix the problem is remove the latch assembly and thoroughly clean it to remove all the grease and grime. Once clean, you can locate the offending broken spring. Mount the latch in a vise where you can have good access to make the repair. You will see that the spring is held in place by 2 short tabs that are bent at a 90 degree angle to the latch and pinched together to hold the spring. Use a propane torch with a narrow pinpoint flame and heat the 2 tabs until they are almost red. While still hot, you can then bend them SLIGHTLY; just enough to remove the spring without damaging the tabs. (Be careful with the tabs - you'll need to use them again). Install the new spring in the latch mechanism making sure it's nestled in the right spot and heat the 2 tabs again then take a pair of pliers and pinch them back together to firmly hold the spring in place. After things cool down, use your favorite spray lubricant on all the moving parts and you should be ready to reinstall. I would test it by inserting the handle and make sure it returns to suit you. You can do it!
mcgarrett is offline   Reply With Quote
Old 01-25-2023, 09:25 PM   #10
cmbrucew
cmbrucew's Avatar
Welcome back Professor.
Take the latch with you to Ace hardware, or Lowes, or Home Depot and try to match it.
Once you have the new spring you can see how to heat the tabs and bend them up to access the broken spring. Slowly and carefully. It has been done.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 01-25-2023, 09:31 PM   #11
Old Henry
Old Henry's Avatar
Now that right there is the kind of help that is really helpful. Thanks.
Old 01-25-2023, 10:57 PM   #12
petehoovie
petehoovie's Avatar
Glad 'Old Henry' is still being cared for. Welcome back, Craig!
There's an original right/passenger side front door latch assembly for sale on eBay right now. See > https://www.ebay.com/itm/15525743687...Bk9SR-qrkMS9YQ
Old 01-26-2023, 12:32 AM   #13
Lawrie
Lawrie's Avatar
Graig , welcome back, we have missed you and your travels,
Lawrie
File Type: jpg CA9BB58E-BAFE-443F-A051-6C92CFE03C71.jpg (84.4 KB, 40 views)
File Type: jpg 4D64D358-1B7E-40DC-B15E-F2ECEED04CBA.jpg (72.0 KB, 34 views)
Lawrie is offline   Reply With Quote
Old 01-26-2023, 12:33 AM   #14
Old Henry
Old Henry's Avatar
Yeah, I found a lot of every latch except the driver's door that I need. Darn.
Returned from 18 month mission to Hong Kong in February. Getting ready to go on another to parts unknown. Just got Old Henry out of the body shop where he'd been for 3 months for repair after hitting a deer on a lonely road in Wyoming on a road trip in October. Heading out for a multiday road trip through the Colorado Rockies next week. Glad I've got the newfangled fresh air heater to keep little Lady (15 year old Chihuahua) and me warm.
Old 01-26-2023, 12:41 AM   #15
Old Henry
Old Henry's Avatar
Lawrie
Thanks, Lawrie. Good to see you're still hittin' the road with your great outfit.
Old 01-26-2023, 12:55 AM   #16
Kurt in NJ
Kurt in NJ's Avatar
I used to have a 46, I think there’s a latch in the box of excess 36 closed car latches , I should be going out to my shop by the weekend, I’ll look.
Old 01-26-2023, 02:12 AM   #17
Brian
Brian's Avatar
good to see you back craig, you have been missed
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 01-26-2023, 05:28 AM   #18
Ggmac
[QUOTE=Old Henry;2199273]I just bought a new handle hoping the bad spring was within it but it is not. Is it inside the door?[/delete
Delete
Ggmac is offline   Reply With Quote
Old 01-26-2023, 07:34 AM   #19
deuce lover
deuce lover's Avatar
Try Southside Obsolete in MN.Fred might have one.
deuce lover is offline   Reply With Quote
Old 01-26-2023, 08:02 AM   #20
corvette8n
corvette8n's Avatar
Craig good to see you post, are you planning to record the Rockies trip?. After watching your Arches National park video it inspired me to see Grand Canyon and Arches before the pandemic.
