Old 01-11-2023, 12:08 PM   #1
jeepguy1948
Default What Gear Oil
I know that lots of folks have their own opinions but I’m curious what y’all are using for gear oil. 90 wt and GL4 (that’s the hard part). Even after deciding what then you have to find it to buy it (supply chain blah, blah, blah).
jeepguy1948 is offline   Reply With Quote
Old 01-11-2023, 01:45 PM   #2
cas3
Default Re: What Gear Oil
The O'riellys (?). near me always has 140wt GL4 on the shelf, and sometimes even 90wt, but usually I have them order it. Thats for the trans, I use anything in the diff
Old 01-11-2023, 03:05 PM   #3
Ford Freak
I always use Sta-Lube 140wt. GL4 in trans. & rear axle. I get it from NAPA.
JD CornHead grease works good in the steering box to keep that from leaking.
1952 Ford F1
!956 Fairlane Club Sedan
1965 Falcon Sprint
2007 Mustang GT
Ford Freak is offline   Reply With Quote
Old 01-12-2023, 07:44 AM   #4
aussie merc
aussie merc's Avatar
GL4 140 is available here but has to be ordered generally takes 2 days. Has anyone got any information on GL6 spec and its suitability with yellow metals
aussie merc is offline   Reply With Quote
Old 01-12-2023, 11:01 AM   #5
rotorwrench
rotorwrench's Avatar
I use Aeroshell SAE-50/100 grade motor oil but without the Plus (TCP additive). SAE-50 motor oil is the same viscosity as SAE-90 gear lube. It is packaged as Aeroshell 100 or W100.
The 100 is straight mineral grade and the W100 is ashless dispersant additive which has detergent qualities to hold crud in suspension. I generally just use the mineral based oil but either will work in a transmission.
Use anything you want in the rear axle. There are no soft metals in there unless you have a old Model T.
Old 01-12-2023, 12:00 PM   #6
jeepguy1948
Thanks Y’all, I got the StaLube from NAPA
Old 01-12-2023, 01:44 PM   #7
KJ714
I was just wondering the same thing, great resource
KJ714 is offline   Reply With Quote
Old 01-15-2023, 02:05 AM   #8
The Liberator
I’ve ran the “600wt” form any of the early parts suppliers with good luck but often wondered if any heavy gear lube would be the same? Much easier to run to Napa then order it.
The Liberator is offline   Reply With Quote
Old 01-16-2023, 04:40 PM   #9
jackson
For my '50 Merc Tranny and OD box I use NAPA GL-1.... it contains zero hypoid gear additives.
1950 Mercury mild custom. Original flathead, re-built, bored .040 over, Max-1 cam, Offy heads, Edelbrock super duel with Stromberg 48s.
jackson is offline   Reply With Quote
Old 01-17-2023, 06:21 PM   #10
Brian
Brian's Avatar
"Use anything you want in the rear axle. There are no soft metals in there unless you have a old Model T."
Or a Columbia!! Columbia's have yellow metal components, which may be compromised using GL5 additives?
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 01-18-2023, 10:11 AM   #11
Gene1949
Gene1949's Avatar
CRC Sta-Lube API/GL-4 Multi-Purpose Gear Oil 85W90, Sta-Lube, 1 Gallon, Hypoid Gear Oil, Yellow Metal Safe, Anti-Rust and Anti-Wear Ep Additives
Not to hijack but I changed out the GL-5 and used this in the Muncie in the Camaro. Huge difference (better) in the way it shifts. As soon as it warms up I'm going to do the T-10 in the '49. I believe the T-10 is the big brother to the 49-43 flathead trans, basically a bolt in.
Gene1949 is offline   Reply With Quote
Old 01-18-2023, 10:15 AM   #12
Gene1949
Gene1949's Avatar
I think the additives in the Gl-5 do not play well with the old synchros shift quality. Just my opinion.
Old 01-18-2023, 01:07 PM   #13
Tim Ayers
Excellent. Was going to say NAPA, but looks like you've already got it. NAPA is still a pretty good resource for these old Fords.
Old 01-18-2023, 04:39 PM   #14
joe amorello
joe amorello's Avatar
Sta lube trans and rearend
joe amorello is offline   Reply With Quote
