01-10-2023, 09:57 AM | #1 |
30-31 Coupe vs Sedan fender difference in Radius
I was wondering if anyone had a set of Sedan and Coupe Rear Fenders they could compare the radius on?
I would think they would be pretty close or the very same? Obviously the mounting and width ect is different. Reason I ask is I have a bad quarter bead I was going to use the one for a sedan patch to use ¾ of it to repair my coupe. I could hammer form one I guess but if I could just use this and cut out what I need would be easier. The patch. Thanks! |
01-23-2023, 02:48 PM | #2 |
Re: 30-31 Coupe vs Sedan fender difference in Radius
Well, I took a gamble on it and guess what, you can use it to patch a coupe!
Posting this for others if you need to fix a bad quarter.... Jim |
01-23-2023, 04:44 PM | #3 |
Where did you locate that patch panel - from which dealer? What is their part
number and what do they call it? Thanks |
01-23-2023, 07:35 PM | #4 |
Snyders Antique Auto
A-450-BPR QUARTER PANEL BEAD PATCH RIGHT I’m actually using this to fix this quarter where we have no bead and fill in the gaps. Last edited by ModelAJim; 01-23-2023 at 07:44 PM. |
01-25-2023, 11:03 AM | #5 |
Bob Bidonde |
