12-26-2022, 06:11 PM | #1 |
Seam on the 30/31 oil drain pipe
I have never seen a seem that looked like this one.
Has anyone seen this type of seam before? |
12-27-2022, 02:20 PM | #2 |
Re: Seam on the 30/31 oil drain pipe
Just looked at the 6 i have nothing like that one you have
www.whidbeymodelaclub.com |
12-27-2022, 09:46 PM | #3 |
correct me if I'm wrong but wasn't there two types (lengths) of return tubes because of the two different valve cover plates and their oil return hole positions? Has anyone ever see the cover plate without the return hole? LRF
12-27-2022, 09:52 PM | #4 | |
Like this. |
12-28-2022, 12:01 AM | #5 |
Bob C.: That's the cover! How did the oil return to the pan? Were the oil galleys to the bearings larger? Also noticed NO oil hole in the block. What is the vin on the block and how long was this used? Too many questions I know but this IS unusual and I've not seen a write-up in any national magazine. Thanks for your info. LRF
12-28-2022, 12:31 AM | #6 | |
12-29-2022, 03:00 PM | #7 |
Well, guess I can go back to bed, as I learned something new. Gonna guess that’s a fairly hard block to find!
12-30-2022, 05:05 PM | #8 | |
He says no oil return produced in "limited" quantities, and measured out for production between May and October 1928. Speculates it was a "B-trial" (my modern take) attempting to reduce oil consumption, reduce production costs. Also indicates it was reprised in the Model B (which I consider only partially correct as the Model B cover includes an integral "oil gallery.") Vince also discusses variations with the oil return pipe, the largest (besides the relocation) being a change from early "soldered" ends to brazed ends. He considers the early as somehow "inferior." https://www.fordgarage.com/pages/oilreturnpipes.htm I have heard one can convert short to long pipes (or visa versa) by "resoldering" the end - a move I consider questionable and possibly unnecessary as there are plenty of return pipes around. On Ebay you can even get one in the always desirable and award winning CHROME - to put on your red-painted engine. Red ALWAYS make the car go faster - chrome intensifies the effect. Joe K
Shudda kept the horse. |
12-31-2022, 01:24 PM | #9 |
Most low pressure type steel tubing is roll formed and seam welded with resistance welding equipment that use contoured rollers to clamp and weld the seam as the tube is fed through. Ford used all sorts of different suppliers for things as well as having their own production and one source may have used different type equipment than others. During the process of repairing my fuel tanks, I've noted two distinctly different seam roller welder patterns on fuel tanks that were close to the same MFR date. Some look to be knurled and others have more of an overlap bead look due to the way the seam roller welder machines were configured and possibly adjusted by the operators. It may have been the same for tubing seam welders. Ford had a lot of machines to do jobs like this. This way production could continue even if one was down for repairs or service.
