12-19-2022, 09:42 PM | #1 |
Ford flathead 49 to 53 oil pan difference
Is a 49 to 53 truck dipstick different from a car dipstick
12-19-2022, 11:33 PM | #2 |
Re: Ford flathead 49 to 53 oil pan difference
Watch for Automatic pans also. Newc
12-20-2022, 12:23 AM | #3 |
Yes, they are different. If you look on the dipstick itself, it will have "8RT", "8BA", or "8CM" (Merc) stamped on it.
8RT dipstick: 12-5/8" from cap to Full mark 8BA dipstick: 13-3/8" " " " 8CM dipstick: 14-1/4" " " "
'52 F-1, EAB flathead Last edited by Ross F-1; 12-22-2022 at 07:23 PM. |
12-20-2022, 02:39 AM | #4 |
The tubes are different lengths too.
Best method to check is to put 5 quarts of oil in an empty pan and remark the stick if it is wrong. Or measure the length of tube while it is still screwed into the casting and add 4 7/8", That is the FULL mark. I have done this with 3 pans that I have, they all measured 2" from the bottom of the pan flange to the top rivet. Put a smaller mark 5/8" below that and that means "1 quart low". Makes it easy to estimate how much to add when topping up, |
12-20-2022, 10:21 AM | #5 |
All the different oil pans in the 8BA era have different dip sticks and oil pickup tubes. The Chassis parts catalogs have part numbers and lengths in most cases but it helps to have both car, truck, and Mercury specific parts catalogs to find them all.
12-23-2022, 12:24 PM | #6 |
12-23-2022, 01:49 PM | #7 |
The '49-'51 Mercury pans have rear sumps, while '52-'53 Fords and Mercurys shared the same ribbed center sump pans.
12-23-2022, 02:55 PM | #8 |
This is your 8CM Merc pan. Coop |
12-23-2022, 10:22 PM | #9 |
I have a lot of different tubes and sticks if you find out what you need
