Old 12-11-2022, 08:44 AM   #1
russcc
Default 16" EV8 wheels on a Ford 9".
1. Will the 16" EV8 wheel fit on a Ford 9" rear axle"
2. If not is there a work around or adapter.
3. Maybe and option to buy a '34 that is mostly stock except for Ford 9" which is big negative in my book unless ?
Thank you.
russcc is offline   Reply With Quote
Old 12-11-2022, 09:22 AM   #2
deuce lover
deuce lover's Avatar
Default Re: 16" EV8 wheels on a Ford 9".
Solid steel or spoke wheel? Early Bronco 9" has the same bolt pattern as the early Ford.
deuce lover is offline   Reply With Quote
Old 12-11-2022, 11:10 AM   #3
TJ
TJ's Avatar
If you have the solid steel wheels you can use wheel adapters(easy to find) or redrill the axles for the 5.5 pattern. If you are using wire wheels you can use adapters only as long as the outer ring of the center does not contact the brake drum. Used adapters years ago on a 32 with a 9" and Kelsey-Hayes wires.
Old 12-11-2022, 11:35 AM   #4
Krylon32
Early Ford 15/16 inch steelie's with a 5.5 BP should bolt on to a 9 inch rear also with a 5.5 BP without any adapters. Uses 1/2 inch right hand fine thread lug nuts.
Krylon32 is offline   Reply With Quote
Old 12-11-2022, 03:21 PM   #5
bobH
Can't tell which 9-inch you refer to. In addition to the above posts, and from experience, I can add that if the 9-inch came from a 57-58 Wagon or Ranchero, then there is an option of re-drilling and installing studs for the 5-on 5.5. Eric Vaughn (the wheel guy) used to do this, and made this mod for me, several years ago. At the time, he said that these 57-58 rears were the only ones he knew of that had a large enough axle flange, to do this. (I'm posting ancient history, maybe a dozen years old, and I'll bet there is new info available today. Back when, it was the 57-58 version that was chosen because it has the correct width to look right under a 34.)
bobH is offline   Reply With Quote
Old 12-11-2022, 05:29 PM   #6
flatjack9
flatjack9's Avatar
They will fit on a first generation Bronco rear.
Old 12-11-2022, 07:40 PM   #7
russcc
Thank you all. Looks like want to find out what Ford 9" is under the car.
I would likely by using some 16" Kelsey- Hayes bent spoke wires as I have 5 real nice ones.
Old 12-11-2022, 07:42 PM   #8
paul2748
paul2748's Avatar
Many of the F 100's had the 5.5 inch bolt pattern
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 12-11-2022, 09:37 PM   #9
flatjack9
flatjack9's Avatar
I don't believe Kelseys will fit over the drums.
Old 12-11-2022, 09:41 PM   #10
V8COOPMAN
V8COOPMAN's Avatar
Currie Enterprises can supply you with axles custom fabricated to fit your 9" rear, any bolt pattern. Click on the link BELOW!
Coop
https://www.currieenterprises.com/cut-to-fit-axles-2
Click Links Below __
T5 W/TORQUE TUBE
Old 12-12-2022, 05:40 AM   #11
deuce lover
Speedway sells the adapter spacer for that exact application.Here is a link
https://www.speedwaymotors.com/Alumi...nch,94209.html
