12-06-2022, 10:58 AM | #1 |
paint removal
What have some of you guys used to remove the old paint to get the car to bare metal? Soda blasting is not an option for me. I would like to use some kind of chemical remover
12-06-2022, 11:06 AM | #2 |
Re: paint removal
I’ve used this in the past, available at hardware and most auto parts stores.
12-06-2022, 12:03 PM | #3 |
Re: paint removal
If using a stripper you will need to spend a lot of time cleaning and neutralizing all the small crevices in the body and fenders. Not properly cleaned it will come back to haunt you in your new paint job.
12-06-2022, 12:56 PM | #4 |
Re: paint removal
I'll add that the new formulation of Aircraft Stripper does not work as fast as the old. It will work, however. I would follow up with a DA and sand the body also. Like TJ said, make sure you clean any residual stripper off the body.
12-06-2022, 02:55 PM | #5 |
Re: paint removal
I use paint stripper and a putty knife to scrape off as much as I can.Then follow up with the HF abrasive wheel on an angle grinder.
https://www.harborfreight.com/4-1-2-...eel-94017.html It will leave only VERY fine scratches in the metal.Just don't hold it one place too long and use light pressure. |
12-06-2022, 04:37 PM | #6 |
Re: paint removal
I have Harber a Freight sand blaster I use to get into small areas like along a drip rail or a door jamb or rust pits. You have to get that rust out of those pits or it will evetually bubble up under the paint. Sand blasting large panels like quarters will warp them just from the heat the friction causes. Wipe down the bare metal with acetone until the paper towels are staying white. Then wipe it down with a tach cloth. Do not touch the bare metal with your hands. The oil and moisture will cause it rust in those spots you touch. If you have to move the panels, do it with latex gloves on. Immediately prime the panel with a primer designed for bare metal. That is the biggest problem people make. They strip stuff to bare metal and then it sits and rusts. Only strip to bare metal what you can clean and get into primer in the same day. It's expensive buying all those quality supplies just to get the parts into primer. I've seen this Eastwood paint conditioning tool advertised and I'm thinking about buying one. I think I will still remove as much as I can with paint remover and then run this tool over it. If really works as good as the video shows and it save the price of buying the paint remover that would be great. I found a clone of it Harber Freight is selling. You get what you pay for. Eastwood Paint Remal Tool https://www.youtube.com/watch?v=xV8U_RXUfd4 Harber Freight Tool https://www.youtube.com/watch?v=_Juia3HJzX4 |
12-06-2022, 05:34 PM | #7 |
Re: paint removal
The old stuff worked so fast you could hear the paint popping up and off. I have a feeling the new stuff may be like new carb cleaners. Not as effective but all a person has.
12-06-2022, 11:23 PM | #8 |
Re: paint removal
I used jell Strypeeze paint stripper on our '41. taped over all seams with duct tape. took 2 applications and was down to bare metal. first round and paint rolled off with a razor blade. second coat finished any left-overs. washed with paint thinner multiple times and D-A sanded entire body. had no issues with paint. stripped seams manually
12-06-2022, 11:37 PM | #9 | |
Re: paint removal
How long ago? EPA outlawed methylene chloride which was the main ingredient in strippers. What I have used the last couple years (Aircraft in the blue can) takes several applications and still have to DA like the dickens. Have a '63 Galaxie on the rotisserie right now and will probably just remove the paint mechanically. So we breath the dust rather than the fumes--wonderfull bureaucrats. |
12-07-2022, 09:44 AM | #10 |
Re: paint removal
Thanks for the great ides and links. Now I guess it is just a matter of getting it started.
12-07-2022, 09:55 AM | #11 |
Re: paint removal
I used this stuff from Hime Depot. I leave it on till paint bubbles or softens, scrape excess off with a plastic scraper, then use a scotch brite pad from supermarket with paint thinner. Works great! If it doesn’t come off in all spots the first time then do it again.
12-07-2022, 11:27 AM | #12 |
Re: paint removal
From our fave tool supplier:
https://www.harborfreight.com/9-amp-...op-customers-1
Henry Ford designed the flathead without the aid of a computer. |
12-07-2022, 12:18 PM | #13 |
Re: paint removal
If you are going to do the bodywork why not sand it to bare metal (block sand) ? This will identify the areas needing work and you won’t need a guide coat. You may also find that it has rust under the paint which will require treatment prior to primer.
12-07-2022, 10:50 PM | #14 | |
Re: paint removal
12-08-2022, 11:27 AM | #15 |
Re: paint removal
Great ideas. Here is what I decided to do. I purchased the tool from Harbor Freight and took my fat front fender to bare metal in about 15 min. I then needed to use the paste remover for the dips and around corners. It all seems like it will work great for me.
thanks to all |
