Old 11-30-2022, 04:50 PM   #1
busmania
busmania's Avatar
Default I’m sure it’s been asked but I need help with removing valves
I’m really not trying to overwhelm the board with questions but i’m stuck.
I’m trying to remove the valves from my 40 block and after 2 hours have had zero luck. I’ve read books, I’ve watched videos Etc but I’m stuck so I come to you.
Do I remove #1 clip first? I have the pickle fork to pry on the springs. If so, what’s the trick? I’ve removed all tension from the spring (I think) and it won’t budge. I tried making a hook tool to hook into the hole and pull, no dice. I’ve put vice grips on it and pulled, no dice.
Or do I pry the other way and remove #2 first? I watched a video where he took the lower clip out first then kinda pried the spring out. It didn’t seem right.
And as a worst case scenario, if I don’t plan on reusing the valves, guides and springs, is it a bad idea to just cut them out?
busmania is offline   Reply With Quote
Old 11-30-2022, 04:50 PM   #2
petehoovie
petehoovie's Avatar
Default Re: I’m sure it’s been asked but I need help with removing valves
Old 11-30-2022, 06:23 PM   #3
aussie merc
aussie merc's Avatar
clip 1 is what holds it all in there and by the look of them they have been in there a long time your on the correct track force the spring toward the cam untill you see a small gap between the spring and the seat and pull out the retainer clip then valve spring and guide should be able to be withdrawn away from the cam [I SAID SHOULD} reality they get stuck Ford made a tool to pull them out as an assembly 50/50 dextron/diesel mix will help loosen them up but patience is required by the bucket load
aussie merc is offline   Reply With Quote
Old 11-30-2022, 06:29 PM   #4
busmania
busmania's Avatar
Patience is no joke. Being one not to give up, I gave it another hour and got ONE lower clip (#2 in my photos) and spring out. Wahoo! But #1 is still stuck. I saw a video where the guy mentioned using a drum brake spring tool (with hook on the end) and a slide hammer. I have both tools but need to come up with a clever way of attaching the two so I can slide hammer it out (unless that’s a bad idea?).
Old 11-30-2022, 07:02 PM   #5
Mart
Mart's Avatar
The crucial bit of info that you might be missing is that you have to move the guide down first. That will free up the uppermost clip. Once the clip is removed the whole assembly can be removed in an upwards direction.
The problem is that the guides are so tight that the normal pickle fork valve tool can't get enough grip on them to pull them down.
I have had good luck using a tyre iron down the intake ports to push the guides down. Horseshoe clips are then removed and the valve removed upwards as stated.
If you can't move the guides down you can try lifting the spring and removing the valve retainer. then lift the valve as far as it will go and yank the spring out of there. Then you use an "onion" tool to go around the valve head and knock the guide down.
Yank the horseshoe clip out and either push the guide up or sometimes you can continue knocking the guide all the way down until the two halves fall out below.
You need a selection of valve compressor tools, pickle fork levers, onion tools, hooks, plus I also have a specific flathead valve removal tool. That is like a big C clamp. It still relies on the horseshoe clip being removed though.
There is also a special spike that is used to yank the horseshoe clips out but that can be hit and miss.
First and foremost try a tyre lever down the intake ports, it is a great labour saver.
If any of the videos you watched were from Mart's Garage that was me.
I have showed valve removal many times.
Some people just launch straight in with the cutting torch but I try and save what I can.
Good luck with it.
Old 11-30-2022, 07:12 PM   #6
busmania
busmania's Avatar
Thanks Mart! On the one valve I’ve gotten free (spring removed) there is no notch for
My pickle fork to grab to push the guide down. It’s just smooth. Does that make sense? I’ll try and grab a photo.
Edit, here’s a photo. No groove for the pickle fork to grab?
Old 11-30-2022, 07:26 PM   #7
Mart
Mart's Avatar
I just watched a couple of videos and jeezus there is some really bad info being spouted.
You need to lift the valve as far as it will go and get something around it to knock the guide down.
There are two schools of thought. First is to try and save as much as possible. The other is to trash everything because it will all be replaced. The videos I saw seem to favour the latter.
Edit: Just saw the pic. The grooves have broken out the end of the guide halves. Your only option is to knock the guide down from above. As it is an inlet try a tyre lever first.
I've got to turn in now as it is late here in the UK. I will check back in the morning. Don't panic or feel like you have to rush anything. Check some of my videos. I have showed it quite a few times.
Old 11-30-2022, 08:28 PM   #8
busmania
busmania's Avatar
Hey Mart, what is your YouTube name? I’ll be sure to check out your videos. Also, what’s an onion tool?
Old 11-30-2022, 08:34 PM   #9
cas3
Yeah, you need the correct tools. here's two different types of the driver to get the guide down, and on the right the pry bar to remove the clips
File Type: jpg EEEDBD0B-0728-48E7-BDD1-DB87E424279E.jpg (74.5 KB, 92 views)
Old 11-30-2022, 09:44 PM   #10
busmania
busmania's Avatar
Thanks cas. That helps a lot. I’m a visual person. I finally got one out! But it was not pretty and won’t be reusable. Since I was going to buy new springs and valves and all that jazz anyway (3-4 are stuck, lotta rust etc). I think the time to cut the rest out has come. I don’t want to damage the block by prodding and prying on parts that I’m going to replace anyway. So, what’s the best way to cut these out? Plasma cutter? Dremel? Cutoff wheel? I have all of the above. Can I cut springs and valves or should I remove springs first?
Old 12-01-2022, 01:07 AM   #11
deuce_roadster
deuce_roadster's Avatar
I have a tool that looks like a C clamp that reaches in and after the big horseshoe clip has been removed, pulls the valve, valve guide and spring all out as 1 unit. I have never found a guide that was too rusted to be pulled with this puller. Tomorrow I will put pictures of this tool in my MISC folder.
Old 12-01-2022, 02:07 AM   #12
cas3
If you are planning on all new, then, yes many folks just cut all the springs with a torch, and then pry the valves up , cut the heads off, and drive the guide and stem down into the valve chamber. Depends on if you are just trying to freshen up an old motor, or a complete rebuild. Mart has several videos on his youtube site about tearing down stuck motors. I saw your posts at the hamb, nice car you got, post some pics for the guys here
Old 12-01-2022, 09:46 AM   #13
Jack E/NJ
Jack E/NJ's Avatar
Since the clip & guide are usually bonded to each other and the block, a drift like Mart's or cas3 easily releases the clip without busting a guide lip trying to pry it down.
To complete the job, insert shims between spring coils with valve closed. Slowly turn crank a bit to let the camshaft push the guide up just enough so that a thick shim will fit between the lifter & mushroom.
Then back off the cam, remove coil shims & insert thick shim. Stick a catch bucket over the valve head. Turn the crank to fully depress the spring.Then walk away & let spring tension & penetrating oil do their magic.After a few hours. the whole valve assembly will often be found in the catch bucket.
Jack E/NJ is offline   Reply With Quote
Old 12-01-2022, 12:08 PM   #14
deuce_roadster
OK, This is the tool that has always worked for me. Note the notch at the small end of the tool, that goes into a groove at the small end of the guide. At the top the part that gives the valve head room to come up is on a swivel. Once the large horseshoe clip that holds the guide in the block is removed this tool forces the guide, spring and valve out as a unit. I have only had to put a cheater bar on the handle once but it has always worked.
Picture is also in my MISC album.
I just looked and there are several of these K&D 918 valve guide tools on Ebay now.
Old 12-01-2022, 12:24 PM   #15
Mart
Mart's Avatar
^^ I have one of those tools and it has saved my bacon a few times. The notch at the small end (of mine at least) is sized to go around the valve stem diameter. It would not go into the grooves on the guide.
I never know whether the small blade is supposed to go against the end of the guide halves or whether it is supposed to just pull up on the spring until it goes coilbound and pushes the guide up.
It was a very lucky swap meet find here in the UK.
Mart.
Old 12-01-2022, 12:39 PM   #16
deuce_roadster
I guess it fits some guides and if not, will push on the bottom after clearing the valve stem. Either way it is a great tool.
Old 12-02-2022, 12:30 AM   #17
cas3
You like pictures, some more tools. The clamp thingy is like Deuce posted, its a K&D 918 valve guide puller. The center tool is a tire spoon I cut a notch in to fit around the valve stem and pry up the spring to get the keepers off, and on the right is the real tool for that, that I just bought at a swap meet last year and have not used it yet. Note the is a big and small size notch, not sure why. That tool is a Lectrolite model 500 made in USA. I believe Speedway sells them new, or a chinese copy anyway
File Type: jpeg B2DE9054-D44B-4454-9D01-FEDC775BE92B.jpeg (96.9 KB, 48 views)
Old 12-03-2022, 12:42 PM   #18
rotorwrench
rotorwrench's Avatar
I have the All Power removal tools. One is used to lock onto the tongue of the retailer clip and pry it out and the other is a wedge tool with a slide hammer to drive the valves up from the bottom.
The 8BAs are easier due to removable keys to get the valve out of the guides. The mushroom tip stems usually require a driver or puller like the KD type. I've had some stuck bad enough to pull the crank and cam out first and then drive them out from below. Where there is a will, there is a way. If all else fails the cut the valve stems.
Old 12-03-2022, 01:37 PM   #19
deuce_roadster
I also have the All Power tool to get the keepers out. You must clean the tab of oil and sludge so the knurled part can bite into it. You insert the tool and slide the keeper tang into it. There is a lever to release spring tension. I would highly recommend picking one of these up if you see one for sale. Close up of knurled part that grabs the tang
[IMG][/IMG]
Old 12-03-2022, 02:20 PM   #20
L-head
The All Power valve tools are great. I wish someone would make them again. When all else fails, cut the springs and the valve stems. I have scars on both hands from engines that I have torn down. The K-D 918 tool is a good one; they also made on for 60hp engines.
L-head is offline   Reply With Quote
