Old 11-29-2022, 05:07 PM   #1
28fordroadster
28fordroadster's Avatar
Default av8 enigine placement
I'm sure it's been discussed a hundred times. I'm looking for links to existing threads on the subject.
I am using a model a frame. an 8ba, I have choices with the body. A 30 coupe or 29 RPU. I don't have to run a hood so I can move the radiator forward. I am running a 39 top loader and have the choice of the model a rear or a 39 rear. I am willing to cut the torque tube.
I think my biggest questions are.
Are all the flatheads' lenght the same?
Do the fan choices take up more or less space?
I don't intend to run an alternator or electric fan
Thanks for your help
28fordroadster is offline   Reply With Quote
Old 11-29-2022, 06:11 PM   #2
cas3
Default Re: av8 enigine placement
The 59a design is about an inch ana half shorter than the 8ba's, due to the crab dizzy. you can dress up the 8ba with 59a heads and dizzy to get that length. You will have to make a custom driveshaft and torque tube, no ford parts are a bolt on for that. The early style fan on the generator is the shortest/easiest I believe.
cas3 is online now   Reply With Quote
Old 11-29-2022, 08:17 PM   #3
bobH
Regarding 'placement'... My approach (I've only done this a couple times) is to have the stock Model A rear end in place, attach a V8 trans and 59A-type block with 48-earlier water pumps, and put the front motor mounts on the frame, to match. (My simple mind.) I even used this same approach to put a 265 Chevy in a model A. Everything was made to fit, from there. (For the case of the 265, a Hurst-type front engine mount, sitting on flathead Ford biscuts, bolts right in. I also used this approach putting a 265 in a 47 Ford. Totally all bolt-in, no cutting, no welding, no hole-drilling.)
bobH is offline   Reply With Quote
Old 11-29-2022, 09:32 PM   #4
cas3
Good advice from Bob ^^^ on placement. Some folks get along fine with the A rear end, then the drive shaft and TT problem is done . The 39 rear is a little more desirable for several reasons, and the solid shaft can be shortened and used without a center bearing due to the short model A wheelbase
Old 11-29-2022, 10:33 PM   #5
30Murray
I have a similar setup. I found the 8BA wouldn't fit between the rad and firewall so used a generator mounted fan. Also I had to recess the firewall to clear the block and fuel pump plus room to remove the right head if needed. I used a '34 rear end and shortened the torque tube about 10". The model A ttube was a little too short. I would recommend getting a copy of Vern Tardell's book which details this setup.
30Murray is offline   Reply With Quote
Old 11-29-2022, 10:53 PM   #6
Pete
Where you mount things is a matter of what you intend to do with the car.
No alternator or fan sort of indicates some lind of competetion.
If handling is important and with original type cross springs, the engine should be mounted as far back and high as is practical. The rest of the parts can be made to fit.
The 39 rear end is by far the better choice. Much stronger.
Old 11-30-2022, 05:58 AM   #7
Tim Ayers
Get the book in the link below. It will walk you through every step a long the way.
I just went through this with a '28 roadster on a '32 frame. Using a single belt set up with a generator mounted fan, 59 AB style water pumps and crank pulley will give you the most room. Absolutely check clearances before final welding and you'll be fine.
https://www.verntardel.com/store/p28...Winner%21.html
Tim Ayers is online now   Reply With Quote
Old 11-30-2022, 03:29 PM   #8
28fordroadster
thanks for your feedback. I'll be happy to hear from more of you
Thanks again
Old 12-01-2022, 01:28 PM   #9
rotorwrench
rotorwrench's Avatar
There is some good information on the HAMB for 8BA series engines in AV8 cars. I've seen some decent front mounted fan set ups using an offset generator. Converting to 29A or 59A series frontal equipment does help but the timing gears and cam have to be changed to get the thrust right with the earlier distributor. The block needs a little mod to use center port heads. I like the Merc pan and half bell if using an old Ford transmission.
Thankfully, a lot of stuff crosses over between the early and late flatheads.
rotorwrench is online now   Reply With Quote
Old 12-03-2022, 12:04 PM   #10
alchemy
alchemy's Avatar
Wow, the Fordbarn is really turning into a hot rod place now!
alchemy is offline   Reply With Quote
Old 12-03-2022, 02:06 PM   #11
DavidG
DavidG's Avatar
Which is not necessarily a turn for the better. What say you, Ryan?
Old 12-03-2022, 03:43 PM   #12
Ronnieroadster
Ronnieroadster's Avatar
Did I miss something the post is about Ford flathead engine lengths and Ford body types. Doubt there's a mission statement that limits the applications for given posts to just original, stock and restoration?
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block
First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921
First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587
Ronnieroadster is offline   Reply With Quote
Old 12-03-2022, 04:07 PM   #13
28fordroadster
It's all ford baby!
You guys have given me alot of leads and good info
Thanks
Old 12-03-2022, 04:27 PM   #14
J Franklin
J Franklin's Avatar
The Model A Rear end is weaker than later ones because the later ones held the pinion gear on both sides to stop deflection. Use the later axle.
Old 12-03-2022, 07:02 PM   #15
DavidG
DavidG's Avatar
Actually there something of mission statement which evidently some of you have missed at the very beginning of this forum under the title "Hey Fellas.....Some Clarification" wherein the owner of this website specifically excludes hot rods and suggests those interested in them should to the HAMB website.
Old 12-03-2022, 08:13 PM   #16
alchemy
alchemy's Avatar
I'm a member/user of both Fordbarn and the HAMB. I come to Fordbarn for specific topics relating to old Ford cars and parts. I don't seek or discuss hot rod specific stuff here.
I go to the HAMB for hot rodding my old Fords. I know they won't be upset if I talk about cutting something or switching parts around. I understand the purpose of each, and have really been surprised lately by the allowance of hot rod talk on Fordbarn.
I invite the OP to come over to the HAMB for his measurements. Don't take a dog to a cat show, even if they both have fur.
Old 12-03-2022, 08:25 PM   #17
bobH
I suppose all this 'yakkin' implies we should kick off folks like Ronnieroadster, old Ron, Pete, myself, and a host of other folks. With respect David, I generally enjoy what I pick up here, even if it involves modified flatheads. I don't do hamb at all, except if there is a specific link posted here. So, I hope things remain pretty much as they are. obviously, opinion.....
Old 12-03-2022, 09:09 PM   #18
DavidG
DavidG's Avatar
Not at all, but the case of 28fordroadster clearly crosses the line and moves away from the status quo.
Old 12-03-2022, 10:04 PM   #19
tubman
tubman's Avatar
Oh no! I'm gonna miss the videos that "Mart" makes.
tubman is online now   Reply With Quote
Old 12-03-2022, 11:32 PM   #20
GB SISSON
GB SISSON's Avatar
My stuff is so far in left field, what with the totally non ford wood wagon body on a jailbar pickup chassis, the diesel powered '47 tonner and let's not even start on the 4wd Foyota RPU. If I recall correctly all three were quite well received. I have chosen not to share my homespun jalopies on the hamb site because I feel at home here and barners seem to tolerate my antics. I don't know where else I would go. I build and paint my trucks with what I have and in such a way that they could be used as farmer's vehicles on a movie set depicting a small town in the '50s/early '60s. Think the opening scene in the movie 'Hoosiers', set in rural Indiana in 1951....
