Old 11-28-2022, 09:04 PM   #1
3twinridges
3twinridges's Avatar
Default 7ra v8 distributor
Thanks guys for the guidance on color. I painted the distributor cast iron and it looks great. So far new bushings, new breaker plate, wiring and points. Condenser checks out within specs. Waiting on a new vacuum canister to mount on the bench before I install the shaft/gear.
Before I insert the wick and oil cap, should I inject some oil in the hole first? Or just install the wick and oil that?
JB
File Type: jpeg 85B9A284-7D82-4001-B3C8-F27C200C8256.jpeg (90.0 KB, 233 views)
File Type: jpeg 1C14C8F2-0644-4BC4-A8A2-27D664C4C710.jpeg (88.8 KB, 230 views)
3twinridges is offline   Reply With Quote
