Old 11-25-2022, 03:19 PM   #1
The Geezer
The Geezer's Avatar
Default Vintage Tire Gauge Question
Hi all,
Does anyone know how to open one of these to clean and lube? I can’t get the bezel off to get to the dial face.
Regards, The Geezer
File Type: jpg 0A38E329-22A6-49E1-B857-7F4C7C5C340F.jpg (64.0 KB, 73 views)
File Type: jpg 49E418F5-E5D9-4FBA-B1C5-BCF54F4CE949.jpg (48.1 KB, 63 views)
“Finally driving a car older than me!”
The Geezer is offline   Reply With Quote
Old 11-25-2022, 10:24 PM   #2
Gary WA
Gary WA's Avatar
Default Re: Vintage Tire Gauge Question
Is it a screw on rim? I have a couple but never tried to take apart!
www.whidbeymodelaclub.com
Old 11-26-2022, 09:02 AM   #3
nkaminar
nkaminar's Avatar
Take it to a watch maker or watch repair shop. There is a special tool that grabs the edge of the bezel all the way around and squeezes it. This compresses the bezel to remove it. There is also a special tool to pull the pointer off and some screws that attach the face plate. If you cannot find a watch maker you may be able to pry the bezel off with a sharp knife, like a #11 Exacto blade, but you stand the chance of damaging the bezel.
Maybe the best thing is to leave it untouched and put it in a display case, then go buy a modern gauge.
Old 11-26-2022, 05:59 PM   #4
The Geezer
The Geezer's Avatar
I finally was able to get the bezel off using an exacto and tapping with a jewelers hammer. It wasn’t a screw-on. Will be cleaning and calibrating it and put it back together like it was originally.
Thanks to all who offered suggestions. This forum is awesome!
Old 11-27-2022, 12:12 AM   #5
Conaway2
Conaway2's Avatar
Pls update us as you work on the gauge….I have a couple of these that I would like to get working again, and will be very interested in following your work.
Thanks - Jim
Conaway2 is offline   Reply With Quote
Old 11-27-2022, 11:54 AM   #6
katy
katy's Avatar
Originally Posted by Conaway2 View Post
Pls update us as you work on the gauge….I have a couple of these that I would like to get working again, and will be very interested in following your work. Thanks - Jim
Ditto, except I only have one that needs TLC.
Old 12-11-2022, 07:30 PM   #7
The Geezer
The Geezer's Avatar
I was able to get the bezel off with a small fine screwdriver. Also removed the 2 screws on the back. Then unscrewed the stem off. You can then wiggle the dial and mechanism out of the case. I took a soft artist paint brush, dipped it in alcohol and “scrubbed” the mechanism being careful not to get alcohol on the dial face (just in case it might smear or kill the printing!). Blew out any dirt or dust with an tire air compressor. I oiled all the pivot points with a very light sewing machine oil. I then put the mechanism back in the case and screwed the stem back on. The bezel was left off at this point. I checked the accuracy on a tire with known pressure. The gauge was off a bit so I popped off the pointer on the dial face after zeroing the pointer. After popping the pointer off I tested the known tire pressure again. I then put the pointer back on pointing at the known pressure. I rechecked a few more times and pressed the. Bezel back on. My Ford tire gauge now works just fine. Hope your repairs/cleaning goes well too!
Old 12-11-2022, 11:18 PM   #8
hrant
Thanks for the update, and kudos to your success!
hrant is offline   Reply With Quote
Old 12-12-2022, 07:54 AM   #9
Redbird
Redbird's Avatar
Any photos taken during the process?
Redbird is offline   Reply With Quote
Old 12-12-2022, 09:45 PM   #10
The Geezer
The Geezer's Avatar
No, could have done that, but didn't know it would have been of interest to others.
Old 12-13-2022, 11:27 AM   #11
dropacent
dropacent's Avatar
We started with about 130 of these and have rebuilt and restored many over the last couple years. We have 30 remaining and can restore with the model A face, several early ford fantasy faces, and also can do special make autos. U S gauge made at least 25 different faces, as we have that many in our collection.
It does take special tools to open and close a case without damaging or scratching it. Glad to do that for free , but with postage at $5 minimum each trip it gets expensive.
dropacent is offline   Reply With Quote
Old 12-13-2022, 02:09 PM   #12
dropacent
dropacent's Avatar
Pics of other US gauges
File Type: jpeg B7FDC246-3781-4DB1-9532-F0262B0099A7.jpeg (148.3 KB, 73 views)
File Type: jpeg 583F0CFF-8014-46D9-9944-EEABF03E4CF1.jpeg (118.7 KB, 64 views)
Old 12-13-2022, 08:48 PM   #13
David in San Antonio
David in San Antonio's Avatar
@DropACent - The emphasis on the 35 on the gauge faces answers one question at least..,
David in San Antonio is offline   Reply With Quote
Old 01-03-2023, 02:51 PM   #14
ford28a
Hello, who still repair tire gauges, what is the cost? Or can someone post how to fix these?
Thank you
ford28a is offline   Reply With Quote
