11-06-2022, 07:42 AM | #1 |
'32 gas gauge I just restored
Some of you know that I do these.This is a rare French '32 Ford gas gauge (P instead of F on the face) I finished this morning.The line was plugged so bad that neither acetone or brake clean would free it up.Had to use diluted Chloric acid.Before and after pics.
11-06-2022, 08:03 AM | #2 |
Re: '32 gas gauge I just restored
deuce lover,
Wow does that look nice. How do you clean inside? Regards, Chris
1932 AAB Truck 1953 Ford Jubilee 2015 Ford F250 SuperCrew Lots of Allis tractors Some Cub Cadets |
11-06-2022, 08:13 AM | #3 |
Chris,I carefully take it all apart ,bead blast the case or wire wheel depending how rusty(some don't need it),clean the line using paint spray gun brushes from HF and acetone or acid,clean the lens,make new gaskets,make a new white paper backing,0000 steel wool to clean the chrome then reassemble.Thread chaser on the threads.Small blow gun tip w/compressed air w/pressure turned down is necessary also.
11-06-2022, 08:17 AM | #4 |
WoW! Colossal gauge now!
I have a '33 that hasn't been touched in 87 yrs, assembly line. Like the rest of the car.(other'n one repaint.) |
11-06-2022, 08:20 AM | #5 |
Highbeams,Here is a '33-34 I did a couple months ago.
11-06-2022, 09:07 AM | #6 |
11-06-2022, 09:15 AM | #7 |
Thank you !!
11-06-2022, 09:47 AM | #8 |
Nice job. I also have done a bunch of 32-34s for the swap meets and it is satisfying to bring back a scuzzy looking mess to like new condition. You can tell if it is going to work by rapidly tapping your finger on the inlet tube and seeing liquid move up the glass. One of the vendors sells the gaskets that go in by the lenses (or maybe they used to).
11-06-2022, 10:45 AM | #9 | |
Coop |
11-06-2022, 10:53 AM | #10 |
Thanks Coop !!
11-06-2022, 05:46 PM | #11 |
Excellent work, very clean and authentic. Only if these gauges were a bit more friendly to restore I would love to have mine work properly. I substituted a later year needle gauge and it has been loyally assisting almost 20 years.
1928 "A" Phaeton (mid year with many early features) 1933 "V8" Closed-Cab Pickup Truck (originally a Model B, 4 Cylinder dating to May, 1933)
11-07-2022, 06:36 AM | #12 |
Great restorations!
Glenn |
11-07-2022, 06:43 AM | #13 |
Really nice job - exceptional work! Thanks for sharing.
11-07-2022, 10:53 PM | #14 |
Sheldon -I presume the french word for full begins with P? Great work !!
Such a fine sight to see-Its a Girl, My Lord, in a Flatbed Ford slowin' down to take a look at me. |
11-08-2022, 12:43 AM | #15 | |
That "P" stands for "Plein"! Sheldon's probably still snoozin'! Coop . |
11-08-2022, 12:57 AM | #16 |
Just woke up.Yes P for "plein".I should have mentioned that in first post.Sorry.
Now searching for the Spanish,German,Dutch etc versions Last edited by deuce lover; 11-08-2022 at 01:03 AM. |
11-08-2022, 03:52 PM | #17 |
Are yes I remember now -I once saw an Australian woman on a french flight who when offered more food responded with "Je suis plein" ( I am full) which is a phrase in slang french that means I'm pregnant !!
11-09-2022, 10:42 AM | #18 |
I'm really impressed with your work
11-09-2022, 10:45 AM | #19 |
Thank you!
