Old 10-26-2022, 08:27 PM   #1
Granny
Default 0.060 oversize Pistons
Hi Guys
I would like to know If my 1951 C1BA would have any problems with being bored out to receive .060 oversize pistons. I am asking this as machinist is concerned that the block may not take it and course overheating
Thanks for any advise
Granny
Granny is offline   Reply With Quote
Old 10-26-2022, 08:36 PM   #2
tubman
tubman's Avatar
Default Re: 0.060 oversize Pistons
No problem. I have built two 8BA's with a .125 overbore with no problem. I have heard of cases where they have been taken to 3 7/16"+.030 (.280 0ver), but I wouldn't even think about trying that. The only things that could make .060" a problem is extreme core shift or really bad rust.
By the way, have you asked your machinist if he can "sonic test" the block? That will tell you for sure. If he can't, you may want to find one that can.
Old 10-27-2022, 06:57 AM   #3
Mart
Mart's Avatar
Granny, if your machinist is worried at .060, that's chevy type thinking. It would appear your machinist is not familiar with flatheads or sonic testing.
Your flathead should take a .060" overbore no problem.
Old 10-27-2022, 07:07 AM   #4
Tim Ayers
Agreed. .125" is a very common overbore size.
Old 10-27-2022, 10:26 AM   #5
Ol' Ron
Ol' Ron's Avatar
I bore all my engines .125" over, this gives me 20ci displacement increase an 1 point of compression increase. Probably the best way to improve the power and economy of the engine.. The "Perfect street engine"
Gramps
Old 10-27-2022, 07:16 PM   #6
Granny
Thanks Guys I will let him know
Old 10-28-2022, 04:36 AM   #7
Mart
Mart's Avatar
I'd sonic test before going .125". I had one go through to the water jacket at that size.
Old 10-28-2022, 10:20 AM   #8
Bored&Stroked
Bored&Stroked's Avatar
If your machinist knows this little about flatheads and the blocks, what will he/she know about how to correctly do the valvetrain work?
They should have the correct guide-bore pilots (made specifically for a flathead) and not just use a standard OHV pilot inside a flathead valve guide. Do they have the correct pilots?
Do they also understand that the valves on the Driver's side of the flathead are about .043 or so higher (as compared to the deck) as compared to the passenger side? The valves are all the same length, but the relationship to the deck is different due to the crankshaft being offset. I've seen shops do things like try to deck the block to make "both sides the same", sink the valve seats on one side . . . or other dumb stuff - because they have no flathead experience or knowledge.
Think about these things and check with your machine shop . . . before they potentially do "bad things" to your engine (not even knowing they're doing them).
B&S
