Old 10-25-2022, 11:09 PM   #1
31 Woody
31 Woody's Avatar
Default 30 Cabriolet Questions
I have a few questions about a 30 Cabriolet 68B:
- is the hood unique? What other A’s share the same hood?
- is the gas tank unique? If so, what other A’s share it?
- how about the Windshield Wiper? I know that is a pretty hard to find item, is there another A or wiper that can be used/chromed to fill the spot?
- I know Lebarron Bonney closing left a gap in suppliers for interiors and tops—are there any good alternatives for these items for a 68B?
Thanks!
Experience is a cruel teacher. It gives the exam first, then the lesson.
The first 4 hours of a 30 minute repair job are the worst. The next 2 hours usually go much better.
31 Woody is offline   Reply With Quote
Old 10-26-2022, 05:43 AM   #2
Scott NY
Scott NY's Avatar
Default Re: 30 Cabriolet Questions
The hood is the same for all 30-31 A's On the gas tank depends on how early it is oval speedo early round speedo mid to late 30 again on the wiper early 30 used an electric and mid changed to vacuum wiper
Scott NY is offline   Reply With Quote
Old 10-26-2022, 06:35 AM   #3
Mike Peters
Mike Peters's Avatar
https://www.classtiqueupholstery.com
Mike Peters is offline   Reply With Quote
Old 10-26-2022, 07:51 AM   #4
Kevin in NJ
I suggest you become involved with the cabriolet club for better answers to the other questions you will likely have.
What kind of wiper is correct for your car? If it is potmetal then it cant be rechromed sucessfully. If potmetal is bad anywhere they dont like to even attempt to chrome plate.
You also should not replate an original windsheld frame. They rust from the inside fast. You are wise to buy a top quality original from a dry area and have that plated. Keep in mind the back side is painted flat black originally.
Kevin in NJ is offline   Reply With Quote
