10-14-2022, 06:36 PM | #1 |
Leaking rear hubs/axle seals.
35/36 rear, new seals ,well 500mls. grease slinging out on the outer hub and inner seal area. Brakes are clean and dry ..Now anyway. Any thoughts appreciated.
10-14-2022, 08:31 PM | #2 |
Re: Leaking rear hubs/axle seals.
Do ou have the seal in the correct way?
10-14-2022, 09:22 PM | #3 |
What grease did you use?
Bruce
Works good Lasts long time |
10-14-2022, 09:24 PM | #4 |
Something like this. The steel ring of the seal facing the axle housing and the lip of the seal facing the hub carrier bearings.
10-15-2022, 02:42 AM | #5 |
To much grease?
10-15-2022, 07:40 AM | #6 |
10-15-2022, 07:56 AM | #7 | |
Thanks! D |
